New E55 spotted at MIR drag today (11.6 @ 12x.xx)
Old 05-31-2004, 12:55 AM
mrsteve's Avatar
I don't own an E55 or even a MB but I was at Maryland International Raceway today and there was a 2nd gen E55 that ran 11.6xx at 12x.xx and I wanted to know what the hell you have to do to get it that quick. You guys are really lucky to own such a beast of a car.
Old 05-31-2004, 01:23 AM
vraa's Avatar
Ahem.. nothing
Old 05-31-2004, 01:28 AM
mrsteve's Avatar
No chance you all run that stock. I've seen another one run low 12s at like 115. Something had to be done to it.
Old 05-31-2004, 01:49 AM
dgussin1's Avatar
2016 GLC300 sport
Most likely a chip/pulley and maybe cams/exhaust??? And prolly d/r's or et streets.
Old 05-31-2004, 01:51 AM
vraa's Avatar
Maryland Int Raceway is up north right? If it's cold enough I'm pretty sure the s/c will like it.
Of course someone correct me on this. As long as they get traction they are good to go!
mrsteve's Avatar
He was on stock tires.
I figured a chip and pulley had to be on it.
It had the stock exhaust tips, don't know if any exhaust work was done. Do they make cams for the E55 already?
Old 05-31-2004, 01:52 AM
mrsteve's Avatar
It was 71 degrees. Low humidity.
Old 05-31-2004, 02:00 AM
dgussin1's Avatar
2016 GLC300 sport
Kleeman, Renntech(they wont tell the consumer, only a few people can get them), and Brabus.
Old 05-31-2004, 06:05 AM
stephens's Avatar
E55, F550, S600 Ducati 999
To do a 11.6 would require almost 700hp. 71 F is 21 degrees C, not particularly cold. The only way the car could pull these numbers would be if it was running nitrous. Although I still don't see it putting down this sort of power on stock tyres. It is possible to get this power from the '55 but requires more than a chip and pulley.
Are you sure it wasn't an S600?
Old 05-31-2004, 09:29 AM
norb's Avatar
2009 C63 AMG
And on stock tires to boot?
Old 05-31-2004, 09:39 AM
E55 POWER's Avatar
MB E55 2004
Can somebody say NOS?
Just my honest opinion.
E55 POWER
Old 05-31-2004, 03:10 PM
mrsteve's Avatar
It was most definitely on stock tires. I don't know anyone who buys DR's or ET streets in such a low profile and fits them on such a large rim (they were stock).
It also was an E55 because it had the V8KOMPRESSSOR badging on the front fender.
He got kicked off the track right after his run because if you run sub 14s you need a helmet, which he didnt' have. And if you run sub 12s you need a full roll cage, which obviously he didn't put into his E55.
Old 05-31-2004, 03:11 PM
mrsteve's Avatar
I didn't see a nitrous purge at the start, although that doesn't mean he wasn't running it.
Old 05-31-2004, 04:15 PM
amgrocket's Avatar
13 SL63
11.6 wouldnt be a stock car. ive made 20+ passes and with drag radials 2753518 bfgs ive only manage a 12.2 at infineon in sonoma, granted there is a head wind but no tail wind is going knock off .5 seconds off my 1/4 mile. 11.6 is awesome though!
Old 05-31-2004, 06:12 PM
Sunny55's Avatar
2005 SL55 AMG
lsd?
could that guy possibly have put on a kleemann lsd? i was thinking about getting it to get better 1/4 mile times.
Old 05-31-2004, 07:22 PM
stephens's Avatar
If putting an LSD in would net 11.6sec 120mph+ runs then sign me up. Unfortunately as I stated earlier you need around 700hp to do this. (692hp actually based on a laden weight of 4200lbs)
Old 05-31-2004, 07:33 PM
Sunny55's Avatar
2005 SL55 AMG
headers?
stephens
I am a newbie here...i surf this forum a lot but i've just started to post....i see that u have experimented with ur e55k and i am wondering what your opinion is on a custom set of headers.
I put my e55 up on a lift at my buddy's supra shop and he feels that if i change the headers there is major room for improvements in power, especially cuz of the s/c'd forced induction. i think it would make sense to get better or more free flowing headers. he feels that the stock headers might be really restrictive. what do u think?
Old 05-31-2004, 08:54 PM
vraa's Avatar
Slap me silly, this is the W211 fourms isn't it. I was thinking the viewer saw a S600 also (talk about not reading the article.. or in this case the post)
Old 05-31-2004, 09:14 PM
mrsteve's Avatar
Would an S600 run that fast too? What about the SL600? What does that run in the 1/4
Old 05-31-2004, 09:18 PM
vraa's Avatar
https://mbworld.org/forums/search.ph...der=descending
That's information about Ben Treynor's S600 that runs 11.59.
SL600 is still up in the air, Car And Drive said it did 0-60 in 3.6 seconds but
https://mbworld.org/forums/showthrea...600+AND+driver
offers a lot of criticism about that figure.
Old 06-01-2004, 12:34 AM
Marcus Frost's Avatar
Real Cars
My Supra's drag radials are mounted on 18" wheels and have a 315/30/18 measurement... meaning a side profile that is very similar to most tires in the 315/18 category. You can't tell it's a drag radial unless you look up close, and they do make drag radials that'll fit the stock 18" wheels.
120mph through the traps for a 4200lb sedan is just mind boggling. That's Viper territory...
Would be interesting to know the details on that car.
-m
Old 06-01-2004, 03:11 PM
E55BEAST's Avatar
2004 E55
i ran 11.8 @118 bone stock with radials. ecu and or pulley would give you an 11.6 or lower on radials
Old 06-01-2004, 03:14 PM
E55 POWER's Avatar
MB E55 2004
That's impresing, could you post your slip to see all the times?
Thanks,
E55 POWER
Old 06-01-2004, 08:49 PM
e55 baller's Avatar
W221 S65 AMG
The path to low low 11s
Give it a full season or 2 and I think you will see W211 E55s running LOW 11s with NO NOS, maybe high 10s with an EXCELLENT driver.
If you can cut a 1.8 60-foot at 22psi or so on the stock radials then you should be able to manage a 12.3@115 at a density altitude of 0 feet.
I'd figure the K&Ns drops ins and the snorkle mod is good for 10whp ---> 12.2@116 cost $100
Add the LSD, BFGs, and 283 gearing for the S55 and you should see 11.8@116 (no HP gained) cost $4500
Add the Evosport chip/SC pulley for 50-60 whp and you should get 11.4@120 cost TBD
Add Kleeman Headers & downpipes for 35-50 rwhp should net 11.1@123 cost $4.5k
Add an Eisman race exhuast for 22hp or 10-15 rwhp and you should see 11.0@124 cost $3k
Fix the intercooler efficienty like Stephens is working on and you could pick up another 20-30 whp and end up with ~675hp and 775 tq
note the low trap speed...the wide torque band is what is getting this ET. I have seen Cartek C5s with 500wrhp running 10.7@126 with 1.46 60-foot times. On another note my 700 rwhp/600 rwtq Supra went 10.8@136 and I have gone 12.2@114 at 2,000 ft DA in my E55 so far.
Old 06-01-2004, 11:17 PM
E55 POWER's Avatar
MB E55 2004
Snorkle mod?
Can somebody explain the snorkle mod to me?
Thanks,
E55 POWER
Quick Reply: New E55 spotted at MIR drag today (11.6 @ 12x.xx)
