Screeching noise when full throttle then let off after it shifts
is it belt slip? It’s a loud screech it’s been getting louder right after I did the tune. It’s probably too much HP for the belt? Maybe it’s worn out?
Delete this please, I should’ve searched before asking. Just wanted to clarify but I have my answer! It is indeed my belt, it’s slipping bad. It’s either my belts not gripping recently because I’ve been feeling sluggish since 2 days ago. But the noise is for sure the belt.
![](https://mbworld.org/forums/images/ranks/veteran_marine_corp.png)
And slipping means its generating heat, and eventually the belt will break if this issue isn't rectified.
![slap](https://mbworld.org/forums/images/smilies/slap.gif)
Yes, but when that belt breaks, it tears up a lot of sh*t. Some have even had there hood dented from a broken belt hitting it.
You won’t get rid of the noise. When you spin the tires and then stop, the belt slips. A new belt won’t fix it. A belt wrap kit won’t fix it. It just happens. Not sure why no one else has said this.
The condition of the belt can’t be determined via pictures. Remove it and check for cracks, missing pieces, etc.
The belt screech after spinning tires isn’t going anywhere, and I’m assuminf that’s what you were referring to.
