Air Box Mod
Old Sep 23, 2018 | 05:32 PM
dariuszsonny's Avatar
2007 MB E Class E63 AMG Designo Edition
Air Box Mod
Guys I need help I just modified air box on my 2008 E63 AMG cut out the plastic cover inside air box cover that leads to where the sensor is and inside engine. I just opened it up more in order to get more air goint to the intake into the engine. Car drives very aggressively OMG but it cuts engine when is idling. What is going on to much air into engine or something else. Do I need to go to original air box or just reset CPU. Does to much air causing engine shot down or just sensor is doing this. Please any info will be were appropriated
Sonny.
Old Sep 23, 2018 | 07:33 PM
rocky raccoon's Avatar
W123 300CD, R107 560SL, W211 E320
Go back to the stock air box. What makes you think you know more than those high-paid Mercedes engineers?
Old Sep 23, 2018 | 07:40 PM
Strigoi's Avatar
2001 E320 Wagon, 2006 LBZ Silverado, 2007 E63 (sold), 2001 E55 (sold)
Put the stock air box back on. There's many threads about people doing this and it's not worth it.
If you must have some modded air boxes get the ROW ones. They're a waste of money too.
Old Sep 23, 2018 | 08:58 PM
drothgeb's Avatar
Veteran: Navy
2005 E55
That's a statement made in poor taste considering 50% of the discussions on this board are around modifying the cars... ie... Doing something that improves performance or looks over equipment from "Mercedes engineers"
Old Sep 23, 2018 | 09:55 PM
tw2's Avatar
tw2
I agree. On the other hand though the M156 is not a mod-friendly engine and most of the E55 mods we perform do decrease reliability, pulleys breaking, aftermarket pumps crapping themselves so you could argue either way.
Old Sep 24, 2018 | 07:24 AM
503C43 ////AMG's Avatar
1999 C43, 2008 P30 E63, 2014 SQ5, 2024 Model Y Performance
I was fooled by the hype of the ROW air box. All I got was SKY HIGH long term fuel trims and a CEL. Going back to stock air box this week...
Old Sep 24, 2018 | 01:00 PM
hachiroku's Avatar
SPONSOR
2007 Mercedes E63 AMG
this is the worst thing you can do to your factory airboxes. it introduces dead spots in the fueling map since air is bypassing the sensors. also your idle will hunt as your o2 sensors are constantly adjusting because air is bypassing the sensors.
i've done it myself and hated how it introduced flat spots to my acceleration.
__________________
-BARRY
​​​Follow us on instagram @eightysixtuned
https://www.eightysixtuned.com
Old Sep 24, 2018 | 05:49 PM
Seems most agree with my Poor Taste posting.
Old Sep 24, 2018 | 07:11 PM
I disagree with your comment earlier but agree that the ROW air box "mod" isn't worth it.
Mercedes engineers are hindered by regulations and often try to design a one size fits all package. You can modify your vehicle and have it perform better than how the all knowing Mercedes engineers designed it. Headers are a perfect example, a smaller pulley is a perfect example, different gears are a perfect example, ECU/TCU tuning is a perfect example, etc...
Old Sep 24, 2018 | 07:17 PM
jumph4x's Avatar
W210 DRFT BNZ
Skip to 12 minute mark:
Same applies for most any modern production motor. It is exceptionally rare that original manufacturers leave torque on the table from the factory. Everything out there is extensively researched and tuned for resonance charging.
Manufacturers have known and tuned for this for decades, even things like Acura Vigor had variable length runners way back in early 90s (which BTW is an inline-5 engine).
Leave it be, IMO.
Old Sep 25, 2018 | 11:22 AM
Thank you all guys I just wanted honest opinion This was just experiment and I know now is not worth it. I'm going to original or RenTech High Performance Air Intake Kit.
Thank you from Pensacola Florida
Dariusz AKA Sonny
2008 E63 AMG
Old Sep 25, 2018 | 11:37 AM
Yuille36's Avatar
Veteran: Marine Corps
07 E63 AMG, 10 C63 AMG, 07 E63 Designo, 07 E350, 09 C300, 07 C230
More often the ECU can't cope with the increased air flow that is measured by the MAF sensor, and the injector can't deliver enough fuel flow to get the perfect AFR.
Then comes the dreaded CEL. So your car will most likely require a tune, to compensate.
Old Sep 25, 2018 | 12:24 PM
Thank you Yuille36 That is exactly what I was thinking and yes you are correct the CEL is on LOL Car is out of commission for now in the garage I wont drive it until is corrected. I will go back to factory Air box or RenTech or some other high performance Air box that most likely comes with tuned ECU package unless I could tune this ECU but where ? that is good question Thank you so much for your input that is why we are here enthusiasts of AMG cars to share and help each other with our experiences
V/r
Dariusz Sonnenberg
Sonny
Old Sep 25, 2018 | 01:15 PM
Yuille36's Avatar
I have had the Carbonio CF Intake & Engine Cover with a smaller crank pulley. Along with headers that deleted the primary cats for years, and it didn't require a tune, and no CEL.
The combination of intake, pulley and headers did net me a little more HP and TQ over stock. Conservatively about 525 hp and 470 tq. And you can definitely feel it from behind the wheel.
It pulls even stronger like a freight train.
Old Sep 25, 2018 | 01:46 PM
Strigoi's Avatar
V/r
Dariusz Sonnenberg
Sonny
Jerry at Eurocharged could set you up with a tune. Just have to let him know what mods are done to the car when you get it. They have a handheld unit so you can easily flash the tune at home on your own. It takes about 5 minutes.
Old Sep 25, 2018 | 09:12 PM
Thank you Strigoi perhaps h you have Jerry's contact info? it will be very appreciated
V/r
Dariusz
Old Sep 25, 2018 | 09:43 PM
V/r
Dariusz
just look up Eurocharged and you'll find all you need for the tune. I had a Eurocharged tune but was recently dyno tuned by Race IQ. I prefer the Race IQ tune but since it was a canned tune vs a dyno tune it probably isn't a fair comparison. You'll be happy with either
Old Sep 25, 2018 | 10:07 PM
Strigoi's Avatar
V/r
Dariusz
Just go on their site. They do post on here as well.
http://www.eurocharged.com/
Old Sep 26, 2018 | 01:10 PM
hachiroku's Avatar
SPONSOR
the tune will only help...modified air boxes do not work as the sensor is not pointed in the direction of the additional flow that bypasses the sensor.
Here is my airbox when I removed my lids after I got fed up of the dead spots in my fueling map at throttle tip in. I also have a tune, so no check engine light, but honestly no tune can compensate for the inability to measure the incoming air. the sensor itself is faced the wrong way to work with cutting the trumpet off. If the sensor was further downstream we would have zero issues as all air incoming from cutting of the trumpet will be metered.
__________________
-BARRY
Old Sep 27, 2018 | 03:51 PM
SALES@OETUNING's Avatar
SPONSOR
OE Tuning C63 AMG
Sonny.
This is an old blog post of ours, but it shows the dyno numbers before and after airbox mod and how the airbox mod was done.
http://oetuning.com/blog/c63-amg-dyno-development/
Old Sep 28, 2018 | 01:29 PM
hachiroku's Avatar
SPONSOR
So lost 1hp in the upper RPM's and maybe gained 1-3hp in the lower RPM's...basically pointless mod due to dyno proof. Thanks for the info OETuning!
__________________
-BARRY
Old Sep 28, 2018 | 05:24 PM
SPONSOR
OE Tuning C63 AMG
Just to clarify our findings....
When dataloging air volume on the street comparing OEM airbox against airbox MOD, there was substantial increase in airflow and benefit seen.
The dyno is not a good way to test this airbox mod was the conclusion. Dyno fans cannot get close to the airspeed/ramair needed to replicate on road conditions. (Between 40mph-100mph vehicle/air speed)
Old Oct 2, 2018 | 04:39 PM
Thank you so much I will try Eurocharged and if they wont be able to do it I will go with Westin Engineering ECU Tune plus High performance Air Box as combo tune
I will let you guys how much of performance car will have over factory stock/
Vr
Dariuszsonny
Old Jul 20, 2024 | 10:18 AM
GangStar's Avatar
08' C300 Sport
I've been tossing around the idea of the ROW air boxes, however this thread has me second guessing...
I highly doubt ROW cars had running issues. So if you run ROW air boxes on a US spec, can you replicated the tune of a ROW car?
Old Aug 1, 2024 | 09:18 AM
nd-photo.nl's Avatar
2005 CLS55 AMG W219 C219
For my understanding, what is a ROW airbox?
