Brown Engine Oil, White Smoke From Exhaust...
Man this car is really burning a hole through my pockets...
appreciate the help
don't drive your car...don't run your engine. tow your car to the shop for diagnosis ASAP.
http://www.techenomics.net/tech-blog.../water-in-oil/
- if injectors your oil will smell like gasoline and your oil will become thinner due to gasoline in your oil.
- if leaky valve seal, your oil would look normal, but you could have smoke from the exhaust in certain situations. (idle or lift off/snap closed throttle)
