Headlights ALWAYS stays ON *Help!
My headlights always comes on and stays on when I start my car. It doesn't matter what I have the headlight knob set too. Before the daytime running lights would come on (inner headlights) then the main lights would turn on at dusk/night. *NORMAL! Now it does the opposite!! Main headlights come on including the headlight icon on dash then the inner headlights come on at dusk/night. Please help.
- Note turning the headlight knob doesn't do anythinG... on the off, auto, etc.
2006 E55 ESTATE
Thanks!
By example, with one of my key fobs I display audio with temperature and mileage below; with the other key fob I display audio with mph and mileage below. And just for the hell of it, one key fob brings up the cluster in English, the other key fob brings up the cluster in German. For awhile one key fob had the auto-on headlight feature disabled but I re-enabled it as I prefer having the headlights turn on automatically.
bbirdwell = I tried and still same results. Thx!
KAMG = Thats exactly whats happening... I just replaced the starting line under the hood and wonder if that has anything to do with it. I want to avoid going to the dealership...
Anyone else this issue?!
In the menu (cluster) you can set your headlight to "constant" or "manual".
When you set them on "constant" no matter what the knob is on it will be on (only front lights-at least I noticed)
Set it to Manual and turn the knob to "Auto"
You can turn this functions off/on by using the functions key on the steering wheel to manipulate the settings inside the cluster.
