EvoSport Completed Phase 2 on my E55
Old Jun 28, 2004 | 02:35 AM
DocStone's Avatar
2004 AMG E55
Evosport has been using my car for development of software, pulley system and now shorty headers. The results have been fantastic in terms of quality of parts, increase in horsepower, torque and driveability. They will be posting the actual dyno runs but I am seeing above 480 rwh and above 530 rwt. The headers made a huge difference. Would definitely recommend buying from the Evosport guys.
Old Jun 28, 2004 | 03:28 AM
vraa's Avatar
Sir, this thead is worthless without pics..
Old Jun 28, 2004 | 05:30 AM
Jon200's Avatar
sounds promising but why the headers made such difference?
Old Jun 28, 2004 | 05:32 AM
vraa's Avatar
Doesn't the AMG version of the W211 use the same headers as the 500?
Old Jun 28, 2004 | 07:34 AM
stephens's Avatar
E55, F550, S600 Ducati 999
Congrats, I assume your results are on 91 octane fuel.
Old Jun 28, 2004 | 09:36 AM
e55 baller's Avatar
W221 S65 AMG
Stephens,
Your package is much higher ... 500-540rwhp depending on the dyno and I am sure torque is in the mid/high 500s?
Old Jun 28, 2004 | 01:21 PM
BenzoBoi's Avatar
Super Moderator
W221
Jealous...I am very jealous
Old Jun 28, 2004 | 01:23 PM
BklynBenz's Avatar
CL500
crazy
Old Jun 28, 2004 | 02:12 PM
DocStone's Avatar
2004 AMG E55
Evosport upgrade to 2004 E55
In response to several of the questions:
(1) I will post pictures of the pulley, header upgrades. Evosport, I believe will post the dyno results.
(2) I believe that the standard E55 exhaust manifold is the same as that for the E500 and looks very restrictive.
(3) The headers added about 30 RWH.
(4) The dyno was using 91 gas and corrected for 'sea level' I believe according to Vadim. The actual measured peak horsepower during the run was 490+ rear wheel.
(5) Cooling still seems to be the limiting factor as recognized and addressed by Stephens and others. On the dyno this is a real problem. I believe that Evosport will be addressing this in the near future with a bolt on solution.
(6) The car literally pins you back when you floor it and it downshifts. I believe the combination of the mods has led to this response.
Old Jun 28, 2004 | 02:58 PM
M5KILLR's Avatar
we have 94 octane in va, would there be a little difference? and stephens, do you have any pics? when will your system be available? how much is the #2 evosport package also?
Old Jun 28, 2004 | 08:42 PM
I1 ULOOZ
Guest
Posts: n/a
pics pics pics please~!
Old Jun 28, 2004 | 10:41 PM
otoupalik's Avatar
MBWorld Founder
Hey all,
Here is some info, followed by some specific replies to posts. Look for more information in a press release (found here in this forum also) shortly.
_______
Images:
Here is the dyno from evolution I to evolution II:
Evosport is proud to introduce “shorty” style headers for W211 E55 AMG. Headers are made in California, USA and have following features:
1. Single piece, laser cut head flange for leak free seal, CNC collector flange for precise fit.
2. Aluminized steel construction with 2000 deg. F titanium coating for heat retention and corrosion protection.
3. Designed for easy, bolt in installation without any cutting or relocating of factory catalytic converters.
On our test car they provide an increase of 30 RWHP and 27 RWTQ.
_______
The make a big difference due to the poor flow characteristics of the stock exhaust "log-type" manifold.
Yes, that is correct. This is on CA pump 91.
Originally Posted by e55 baller
Stephens,
Not true. You need to look at the delta. Stephens is using a different DYNO, which reads higher, and also a much higher octane fuel. This is not to discount what Stephens has done at all, just to add some clarification. We could use uncorrected numbers and add race gas, and we would show another 40-50Hp at the wheels. The only way to compare numbers is same dyno & same conditions. Otherwise, look to the delta to give you the story.
_______
Brad
Old Jun 28, 2004 | 10:43 PM
vraa's Avatar
I am under the impression that the bronze looking ones were stock?
Old Jun 28, 2004 | 10:59 PM
stephens's Avatar
Originally Posted by otoupalik
Hey all,
_______
_______
Brad
Brad
The opposite is true of your dyno comments.
A standard W211 E55 produces between 270-280kw (360-375hp) on the Dynodynamics dyno. Your base readings are approximately 10% higher than ours.
A customers car with boost kit and powerchip ECU upgrade only shows 315-325kw (420-430hp), with cooling kit 350-360kw (470-480hp) and with headers 390-400kw (520-535hp).
Our improvement was from 280kW ton 400kW, an improvement of 120kw (160hp) over stock. These numbers have been repeatable on a number of cars upgraded over the past week.
The dyno used is calibrated to 20% transmission losses. It is also placed in what is known as "shoot out" mode which performs auto correction and no manual intervention of any variables. It was developed in australia to provide consistency in dyno shoot oluts across the country.
All dyno's displayed have been with full corrections and Shell Optimax premium unleaded pump gas readily available at the service station, equivelant to your US 92-93 octane fuel.
We do have a "juiced" up version, with a bigger pulley, new front exhaust system with 1st cats removed etc which has shown 430+kw on the dyno, but this is not representative of real results, as I wouldn't be comfortable using that much boost on a regular basis.
Old Jun 28, 2004 | 11:59 PM
Vadim @ evosport's Avatar
C32 AMG
That is preicusely why we have a problem with any other dyno, but DYNOJET. Sorry Stephens, but neither I nor anyone I know, in tuning business, has any experience with Dyno Dynamics dynoes.
The fact that one can change the load tells me that one can also alter the final results. What happens when you set "transmission loss" to a 30%. Does it give you a higher number at the wheels? I am not saying that you would do it, but on DYNOJET the results are all the same. We can take a car from one DYNOJET to another, and there are 15 of them within 40 miles radius and over 200 in US alone - and get the same results.
We are tuning on CA 91 on purpose as this is the worst gas in the world and out biggest customer base. We can not get 92-93 in CA and the one sold in Australia is not oxygenated either. In other words your HP numbers are not achievable in our, CA/US world.
Old Jun 29, 2004 | 12:58 AM
stephens's Avatar
You have misunderstood me, you cannot chnage losses, the software has been designed and calibrated with the belief that transmission losses were 20%. being an experienced Dynojet operator, you would be aware that eralier versions of the Dyno, particularly the units with no brake function,which read around 10% lower than the current models and about the same as the Dyno Dynamics. I regularly use both brands of dyno, particularly with bike tuning and am familiar with the vagaries of the different Dynojet models.
My post was not designed to undermine your achievements, just to correct a potential misunderstanding.
I think you will find an iimprovement similar to what you have seen so far again with additional cooling capacity, as with upgraded boost, from my experience the cooling capacity is not sufficient for even one dyno run.
BTW what was the original stock dyno reading on the car?
Old Jun 29, 2004 | 11:48 AM
otoupalik's Avatar
MBWorld Founder
Stephens,
Thanks for the calrification. Both you and Vadim state good points, however, the bottom line for any dyno is still to look at the delta!
Also, FYI, CA 91 = US 89. CA uses a re-formulation that reduces the true octane even further. Gotta love our state government!
Brad
Old Jun 29, 2004 | 05:21 PM
stephens's Avatar
Stephens,
Brad
Brad, as I aid, it wasn't a swipe, the work you guys have done is great, I love your header design!
I can't wait to line up with a smart alec with a new M5 next year in the E55 and wipe the smile off his face.
Old Jun 29, 2004 | 06:06 PM
otoupalik's Avatar
MBWorld Founder
Yea, not taken as a swipe at all. I just wanted to clarify.
