Shift speed between 55 and 63 w211?
Their are major differences between the two transmissions, the 722.6 transmission in the E55 is much slower than the 722.9 transmission in the E63.
The major differences between the two are:
- The Mercedes-Benz 5G-Tronic (also called 722.6) is an electronically shifted 5-speed overdrive automatic transmission with torque converter lockup (typically in gears 3, 4 and 5) and 2-speed for reverse.722.6 is a 5 speed transmission, used in all the AMG's during that time, as it can handle more torque from the E55's 5.5 liter V8 Due to its high torque capacity (up to 1000 Nm) and lower cost, it was still retained for turbocharged V12 engines, four-cylinder applications and commercial vehicles for many years. It was replaced by the Mercedes Benz 7G-Tronic 722.9 transmission introduced in 2003.
- The 7G-Tronic 722.9 is a 7 speed transmission, offered faster shifting and has a better overdrive gear for added fuel mileage. This fifth-generation transmission was the first seven-speed automatic transmission ever used on a production passenger vehicle. It initially debuted in Autumn 2003 on five different eight-cylinder models: the E500, S 430, S 500, CL 500, and SL 500. It also soon became available on many six-cylinder models. Turbocharged V12 engines, four cylinder applications while commercial vehicles continued to use the older Mercedes-Benz 5G-Tronic transmission for many years. The company claims that the 7G-Tronic is more fuel efficient and has shorter acceleration times and quicker intermediate sprints than the outgoing 5-speed automatic transmission.[1] It has two reverse gear ratios. The winter mode, also recently named 'comfort' mode, starts out in 2nd forward and 2nd reverse. The transmission can skip gears when downshifting. It also has a lockup torque converter on all seven gears, allowing better transmission of torque for improved acceleration. The transmission's case is made of magnesium, a first for the industry, to save weight. The 7G-Tronic transmission is built at the Mercedes-Benz Stuttgart-Untertuerkheim plant in Germany, the site of Daimler-Benz's original production facility.
So the 63 is the way to go if i want faster shifting. Is the shifting in 55 really that slow? I need to test one.
How common where the headbolt issue on the 63?
The E63 shifts aren't as fast compared to today's standards, but pretty quick for the era. I suggest that you drive a E55 and compare for yourself.
What is really slow is the time it takes the electronics to respond on manual shifts.
The large majority of the people that say every M156 is going to grenade from this issue have never even owned one.
That's why I rarely drive mine in manual mode. Hit paddle, wait, wait, wait and it shifts.
I think i would manage the headwork on the 63 if i have som good instructions from say epc. Otherwise i would be pretty lost. How much does mercedes charges for doing headbolts, lifters etc?
The headbolt issue is not as bad as it is made out to be but if you are one of the unlucky ones to hydrolock your engine then... of course if you really like the car it is not impossible to preventatively change them.
One could see it as paying for shifting when doing preventive work with headbolts and such. More fun that way
https://mbworld.org/forums/c63-amg-w...swap-m156.html
https://mbworld.org/forums/w219/6292...-part-2-a.html
Doing them one at a time is not the correct way but much easier, cheaper and seems to work well. Removing the heads is much more work.
Im thinking about the diy mentioned in the first post here:
https://mbworld.org/forums/c63-amg-w...adventure.html
You had to pay for it but the link is now dead and the user does not seem to be active anymore. It would be interesting to see how detailed the guide where.
