Fumoto Oil Drain Plugs?
The concern is they result in reduced clearance between the sump and the ground. Depending on the vehicle this may or may not be a problem.
Thanks for the input. My car is stock ride height and I don’t plan on any major changes under my ownership so I’m comfortable losing a little clearance.
They are in fact slower to drain, but it keeps it very clean. The valves sit up higher than other components (sway bar) so i'm not worried about clearance.
I'll stick with my old school tried, tested and approved drain plug.
FCP. Trying some liquimoly this time around instead of Mobile 1. Anyone else used it before? Just going with 5W-40 from them but bought 2 5qt jugs instead of the kit. Lord knows my car will burn/leak at least a quart before next change.
