W211 bad front ball joint symptom - peeling tread
Old Sep 23, 2019 | 10:15 AM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
Photo attached shows the wear pattern caused by a bad ball joint and/or bushing. In my case, it's the ball joint on the front lower control arm (aka the thrust arm). The tread blocks begin to "peel" back on the tire. Only 72,000 miles ago I had the same wear pattern on both inner and outer edges of the tire; in that case I had bad ball joints on all control arms plus worn bushings. For all the vaunted Mercedes engineering hype, the suspension on this car is pretty sad when it comes to durability. Front and rear suspension rebuilt at just shy of 100K miles and now a partial rebuild at 172K. FWIW, it also appears I could have dialed in just a touch more toe-in. This tire has 36,000 miles on it and I maintained toe at 0.5mm in. When I align it this weekend I'll aim for ~0.75mm in on each side and see how it goes...
Old Sep 23, 2019 | 10:23 AM
Yuille36's Avatar
Veteran: Marine Corps
07 E63 AMG, 10 C63 AMG, 07 E63 Designo, 07 E350, 09 C300, 07 C230
My issue was the rear camber, as I had excessive wear on the inside of the tires, and the other edge looked new. I since then, had a 4 wheel alignment done, to correct the rear camber.
Old Sep 23, 2019 | 12:10 PM
Jake528's Avatar
2005 E55 AMG
Very disappointed in suspension component longevity. Everyone screams, “it’s a high performance, 2+ton sedan! What do you expect!?” Well, I’d expect a little more r&d into the components to combat the weight and power of the car in the first place. It’s certainly frustrating. After just replacing most of my front end (as you saw) I’ve got a pop coming from my front driver’s side; guessing I have an issue that resulted from installment but we will see when I tear into it.
That thrust arm is a pain since everything attaches to it but maybe you can press out/in while it’s on the car!
Old Sep 23, 2019 | 12:17 PM
Yuille36's Avatar
I remember now, I did in fact replace my front thrust arms several months ago. I nearly forgot about it, one of the ball joints was bad, so I replaced them in pairs. Certainly wasn't a cheap fix.
Old Sep 23, 2019 | 01:11 PM
Dokus's Avatar
W211 e500 (Sold), w204 c180, w203 c180, w201 190e, W219 CLS 55
You can replace the lower balljoint on the car with a balljoint press. You also need a heavy duty ball joint separator.
Old Sep 23, 2019 | 01:34 PM
Agent-A01's Avatar
05 W211 E500, 03 C215 CL55 AMG
I suggest getting the HD ball joints from Meyle if you want something that lasts longer than OEM.
Old Sep 23, 2019 | 03:17 PM
coobah's Avatar
'04 E55 Wagon
Hmmmm... here in Europe Meyle isn't anything special and their HD parts seem to be named like that with no reliance to their durability
Lemforder is the brand everybody goes here, but that's actually most of "premium car brands" OEM.
BTW:
I live in Poland. I'd really love to see any suspension on any of my cars live as long as 72K - 100K miles
Old Sep 23, 2019 | 03:41 PM
Agent-A01's Avatar
BTW:
Meyle makes some good parts, some OK parts, and some not so good.
I personally installed the HD balljoints in my 211 and they definitely look beefier.
I've probably put 40k miles on them and haven't had any issues.
Old Sep 23, 2019 | 03:50 PM
Yuille36's Avatar
Lemforder is the name of the thrust arms we used, to replace my old thrust arm ball joints. Each thrust arm cost like $243 each. Good quality part.
Old Sep 23, 2019 | 04:10 PM
Fountain35's Avatar
Originally Posted by Dokus
You can replace the lower ball-joint on the car with a ball-joint press. You also need a heavy duty ball joint separator.
Great video by a forum member;
Old Sep 23, 2019 | 04:16 PM
Ausiblt2006's Avatar
2006 E55 AMG
For anybody that has done this not on a lift how was it? I have watched the awesome video above numerous times but still seems like it would be hard to turn the wrench on the ball joint separator still. seems like the wrench would be on the ground as you try to turn it
Old Sep 23, 2019 | 04:32 PM
Fountain35's Avatar
I don't think it would be that difficult, the guy in the video doesn't look like Schwarzenegger. You can always use a jack handle on the end of a wrench for more leverage. Also, do you have a compressor and an air gun? I think that's all you need.
The main focus here is all the torque specs and tightening the last bolts with the car on blocks to compress the front suspension.
Old Sep 23, 2019 | 04:48 PM
Jake528's Avatar
2005 E55 AMG
AMG Meister is the man. Some great content and that video is a pretty straight forward look at it.
Old Sep 23, 2019 | 04:50 PM
Fountain35's Avatar
Thumbs up
Yeah he is. He is very methodical and his videos are fantastic. I appreciate that he takes the time to do these for the W211 DIY owners.
Thanks Richard if you are reading this.
Old Sep 23, 2019 | 04:53 PM
Dokus's Avatar
Depending on how good your tools are and how married your ball joint is to the arm the experince range from pain to ok. Get heavy duty tools and you should be fine. Get heat torch as well.
I always use lemförder. They make a lot of oem parts for Mercedes. Good quality.
Old Sep 24, 2019 | 03:48 AM
AMGPilot's Avatar
2004 E55
Did you torque the bushings in the air or on the ground? If they were not loaded when torqued they will "pop"
Old Sep 24, 2019 | 06:35 AM
Jake528's Avatar
2005 E55 AMG
It’s been a while but I’m pretty confident it was loaded. It took a month or two to start popping. Only when I’m turning my steering wheel hard.
