Missed fuel pump warranty period and now quoted $2k to fix - what are my options
basically now i need a passenger side fuel pump, but instead of just the $550 part i guess the bill is $2100 at an MB dealer because they updated the wiring and i need other stuff and everything else.
i tried to appeal to mbusa to cover it (warranty on pumps ended 15 months ago) but lost.
i dont have the breakdown of the $2k estimate but im wondering really what are my options? tomorrow im going to mb to try to get the 2k breakdown sheet.
it sounds like just the passenger side top part is leaking right/having trouble...but im told just that shouldnt be fixed it by itself/cant be....
i am willing to go aftermarket if possible. i see people installing aftermarket but im not sure where to being. do i need to find a custom race-shop basically to an aftermarket fuel pump in these cars?
any forum members on the east coast capable of this? willing to pay of course.
really need a e55 friend rn hahaha.
https://mbworld.org/forums/w211-amg/...termarket.html
2003 models aren't trash, you were just an uninformed buyer that didn't know the issues with the car.
Unfortunately you need to cough up and enjoy the car afterwards. It is worth it and yes there are other possible expensive maintenance and repair items that can come up too.
OP, like I mentioned, the parts will cost you ~$1000. Do it yourself in an hour or so and save $1000. Get a fuel tank locking ring removal tool for a few bucks off of Amazon or at your local auto parts store. Jumper the fuel pump relay in the trunk while you have a hose connected to the Schrader valve on the fuel rail to drain the fuel out of the tank (you want 2 bars maximum on the gauge). When you disconnect the fuel lines from the pump, tie a length of paracord around the ends; when you pull the filter/regulator out of the other side of the tank the paracord will come with it. Tie the paracord to the new fuel filter/regulator's fuel lines and use the other end of the paracord to pull the fuel lines back over the saddle hump. Everything on the fuel pump side is a tight fit but it's not difficult, just a few minutes of working everything into place.
Also, be advised that the relays for the non-AMG do NOT correspond to the relays for the AMG. Non-AMG fuel pump relay is in the rear SAM, the AMG fuel pump relay is located on the opposite side of the trunk under the panel. You have to remove the entire side panel as there is no access port. While you are doing the pumps, replace the relay whether it looks like it needs it or not. If you're reading the info I pointed out to you, you'll know all of this by now.
IN THE SHORT RUN
IN THE SHORT RUN
If a guy wanted, pumps and filter could be done on the cheap. Modify the current pump buckets and drop in 2 walbro's (or some other pump manufacturer) and do a paper filter change.
I think the reason for "upgrade" is the cracking plastic top leaking fuel.
