Stumped on ambient air temp sensor issue.
Thanks in advance.
tr
Thanks in advance.
tr
Edit: I see online that it's easy to buy a sensor with a replacement socket so I guess this is a common thing.
Outside Air Temp is part of the speed density calculation that the ECU does in order to properly fuel the motor. the car will NOT run correctly without a properly functioning OAT sensor
IMPORTANT COLD WEATHER INFORMATION
"In order to achieve the low noise level of Lysholm superchargers, Lysholm specifies manufacturing procedures that call for minimal internal clearance. These precise tolerances however are not conducive to temperatures below 25° F. Therefore, storing the vehicle in a heated garage and/or employing the use of an engine block heater/aftermarket engine blanket is required when the vehicle is subjected to a "cold startup" in ambient temperatures below 25° F. Failure to comply with this may result in immediate supercharger failure and invalidate the supercharger warranty."
thanks
thanks
And yes, these beasts are hot blooded and love running in the cool/cold weather!
