Should I buy a 2005 E55 for 7k? 160k Miles
You are also basing your purchase off a start button that probably wont work with all those miles and a 200mph dash that most of them have. You better do some research on these for cost of repairs before you buy.
They were close to $100,000 new back in the mid-2000s. Just because you can get one for cheap now doesn't mean it will be a cheap car to own. Maintenance costs don't go down.
There is nothing more expensive than a cheap AMG.
two different systems one lifts the car one stiffens the suspension.
check all bushings under the car.
chekc if they replaced the fuel pumps since the warranty for the 2005 it’s expired already.
check if all the front seat functions work, specially dynamic function that keeps you centered in the seat when cornering in the highway. as well as massage function/pulse.
check if it has any other ****.
I got a e55 2005 bought it at 160k everything works but it’s better to buy cars at 10k / 110k / 210k because you have to replace miles every 60-100k miles.
These cars are worth how much you put on them, or the previous owner cared about the car.
I bought my 04 in July '19 with 138k miles, one owner car daily driver maintained at dealer but neglected/sat last few years. I have 146k now, drove it throughout the winter, and the car needed:
Gas tank was replaced by dealer who sold it right before I bought it
front airmatic strut leak (replaced both front)
a bunch of gaskets on the engine - oil leaks, including valve cover, oil filler, cam sensor, others (when I replaced one, another would leak)
Alternator
Power Steering pump (cracked)
belts, including SC, pullies, and tensioner pullies
spark plugs
Also needed normal wear and tear like new tires, etc.
Also, other 15 year-old car things can happen. I got a crack in my windshield, likely weak from 15 years of road debris. cracked fog light glass. trunk 3rd brake light some LEDs are out.
Go into it expecting and ready to spend money on repairs, or at least for parts, and to be fixing it or sending it to the shop.
There are plenty of strong engine blocks in the junkyards from all sorts of different cars. $7000 isn’t bad, but only if you can work in the car yourself. A 16 year old Mercedes especially AMG models, isn’t going to be cheap to fix.
A few AMG repairs will make that purchase price seem small.
Answer: Because older AMG’s are too dam expensive to maintain.
But that’s the real attraction to prospective buyers, because they can pick up these cars cheap. Not realizing owning this car is going to hit your wallet very hard.
The moral of this story is, put lots of money away for repairs and maintenance. Or do your repairs yourself.
either way, AMG = All Money Gone (on rear tires especially)
And BMW M5 V10 will cost even more than any W211.
Unless you’ve got extensive maintenance records, of all the services that were performed on the car during its lifespan, I would stay away.
But it’s your money and your call, but I think that you’ll end up regretting your decision later, as many others have gone down this same road.
if you truly want an AMG, gets something that is about 4-6 yrs old.
Even repairing the cars yourself will be much more costly than most cars, simply because lots the parts are specific to the AMG. I own 10 German cars Porsche’s and Mercedes, and they are lower mileage cars. They require repairing about every 2000 miles each. Some small things, some bigger, never really simple fixes, all more complex than they should be. Most parts are much more costly than usual parts.
They are rewarding when they work, but a pain in the rear when they break, which due to their design they do more often than not.
