Noise after swapping over to 5 piece billet aluminum pullies
After installation, it was fine and and could make out the difference as it was quieter until the next day. I started the car in the morning and it started squeaking and would go away after about 15 minutes. The noise has increased since and it’s a week now. The noise is really annoying and embarrassing to drive. The noise however goes away after about 15-20 minutes of driving.
I’m sure many member here have upgraded to UPD/VRP pulley kit. Anyone faced any such issue? Please help address this.
Car is stock. Is it the belt? I used the old belt as it looked good.
I will be however changing the belts as a preventative measure to ensure that the belts aren’t the issue. Will be getting this done this weekend.
Anyone faced a similar situation?
Do you’ll think of any other possibility other than the belt? I’m asking as I can get it done while the car is in for the belt change.
Regarding the accessory drive belt, what would be the best options to the OEM?
Did you replace both the belts?
You’ve been using the K080505HD with stock idler pulley setup or the billet aftermarket pulley kit?
thanks KAMG, appreciate it. I’ll be buying the K080505HD. Hope is available here if not a few days wait if I order it online.
I see most upgrade to heavy duty Supercharger belt, what about the other belt? Is there a green fleetrunner version for that too?
