Airmatic failure? Does this sound familiar to anyone?
Old Mar 29, 2020 | 08:03 PM
Gregc216's Avatar
05 E55
So a couple things happened at once. On my 05 E55 I came out to the driveway and saw the fog lights flashing. I hit the lock button and heard a weird noise from the alarm. Figured it was low on charge due to not driving that much lately. Started right up. No laboring or anything.
After about 20ft of droving i got a warning message im assuming is for the airmatic suspension. Thing rides like it has no springs. The suspension isnt slammed on the ground like i had a leak. Everything seems like its at the correct height. Trying to adjust between comfort/sport 1 and sport 2 does nothing. (After some research found the issue with the fogs flashing. Unrelated but a common thing for the alarm siren failing)
i know without a code or anything its pointless try and diag this but does it sound familiar to anyone? I have a friend that has a tool to comm with the system. Hopefully ill get more info tomorrow.
Old Mar 29, 2020 | 08:49 PM
E55Greasemonkey's Avatar
This place is a joke.
Just happened to me. I never realized the E55 could ride so hard! Fault codes showed my left front acceleration sensor went bad. Replaced it and no more problems. I assume the ESP goes into a limp mode and makes the shocks go full stiff.
Old Mar 29, 2020 | 08:54 PM
Gregc216's Avatar
05 E55
Cool. Was it hard to do? Where did you source the part from? Fcp? Pelican?
Old Mar 29, 2020 | 10:05 PM
hachiroku's Avatar
SPONSOR
2007 Mercedes E63 AMG
you'll need an OBD2 diagnostic scanner that has the ability to scan the airmatic module for faults. it'll tell you exactly what has failed.
__________________
-BARRY
​​​Follow us on instagram @eightysixtuned
https://www.eightysixtuned.com
Old Mar 29, 2020 | 10:22 PM
Gregc216's Avatar
05 E55
My buddy says he has something that can talk to the system. If he doesn’t is there a generic scan tool I can use that will? Like NOT the one Mercedes uses? I was doin some reading but I’m not sure. Will this work?
FOXWELL NT510 Elite for Mercedes Benz Full System Bi-Directional Scan Tool ABS Bleeding TPMS DPF Oil Reset OBD2 Car Diagnostic Scanner(NT510 Enhanced 2019 Version)
Amazon Amazon
Old Mar 30, 2020 | 12:15 PM
hachiroku's Avatar
SPONSOR
don't know about that tool, but Amazon has a great return policy if a product isn't what was described.
__________________
-BARRY
Old Mar 30, 2020 | 02:21 PM
Dokus's Avatar
W211 e500 (Sold), w204 c180, w203 c180, w201 190e, W219 CLS 55
Icarsoft mbII Will do the trick
Old Mar 30, 2020 | 05:17 PM
Yuille36's Avatar
Veteran: Marine Corps
07 E63 AMG, 10 C63 AMG, 07 E63 Designo, 07 E350, 09 C300, 07 C230
Anyone that has owned a AMG long enough with airmatic suspension, knows the costs associated with a repair.
As I recently found out, after 13 years. I had to replaced my front air struts.
Old Mar 30, 2020 | 08:42 PM
Gregc216's Avatar
05 E55
I was lookin at the icarsoft. The one I listed earlier seemed more capable and was only a couple bucks more. I’ll let everyone know if it ever shows up. Thanks to covid19 I prob won’t see it till the end of April. That aside the fault was gone when I started her up today. Drove like a dream. I know it didn’t fix itself. We’ll see what happens. I’ll post again when I know more. Thanks everyone!
