Purge the airmatic system?
To install the coilovers you must remove the rear Airmatic alloy control arms. To remove the outer bolt from the control arm you must remove the rear brake caliper. The mounting bolts are one-time use! WIS also calls out you must run a tap through the hub threads to remove any of the thread-locking compound *before* installing the new caliper bolts. Additionally, the bolts are Grade 10, not 8.8. Much higher torque value for the Grade 10 than the Grade 8.8. So, to reinstall the rear brake caliper, you need the following information:
-Rear bolts A211-423-00-71; $10 from Mercedes
-Tap, M12 x 1.5 mm. Tapered or straight will work but the tapered tap will push against the brake shield in order to clean the threads.
-Torque value for the new caliper bolts is 115 N-m or 85 ft-lbs (not the normally accepted 65 ft-lbs with a Grade 8.8 bolt)
You may or may not wish to lower your car. If you lower it, the increased camber will severely wear the inside edge of the tires. If you don't care, no problem. Your circus, your monkees. If, however, you do care, the proper inclination angle for the rear control arms is the range from -0.9* to -1.5*. This angle is measured on the drive axle and the negative means the hub is *higher* than the differential. If you put the control arm in this range, your camber will fall between -1.7* +/- 0.5*. Negative 0.9* equates to a camber angle of -1.2* and negative 1.5* equates to a camber angle of -2.2*. Also, be advised that since the stock E55 did not come with LSD, the right rear tire will wear out much sooner than the other tires and the wear pattern imitates that caused by too much toe out. Not the case; it's the tire spinning first leaving the line that causes the wear pattern.
This is why you want STAR and WIS. I'd like to see you have a safe car and not ever risk your health or life (or that of your passengers or others on the road) due to lack of knowledge. Plus, it will save you literally hours of your time and time is a finite resource; no gets out of here alive.
To get an idea of what is out there, peruse the following. These folks are out there on the road driving with you and your family.
https://www.reddit.com/r/Justrolledintotheshop/
EDIT: front inclination angle (measured off of the "nubs" on the steel control arm) range is +3.1* to +4.1*. Hub is *lower* than the inboard end of the control arm.
2nd EDIT: The hub has bushing installed where the bolt for the outer end of the control arm mounts. You may need to use bolts/washers/sockets to retract the bushing back into the hub. If not, the new control arm may not fit into the hub. Find a way to retract the bushing so the new control arm will fit. Once you tighten the bolt, the bushing will tighten against the control arm to prevent movement. Good luck and let us know how it works out.
t.
