Cylinder head compatability
Spring code is the same as mine with red/white and I believe valve size and metal meterial is the same. Will these interchange? They look the same but original heads are still on car so can't see casting number.
Spring code is the same as mine with red/white. Will these interchange? They look the same but original heads are still on car so can't see casting number.
https://mbworld.org/forums/w211-amg/...tor-build.html
Performance wise is not an issue if they are close to same plus they will be ported before they go on.
The heads are different and not well suited for the m113k. The exhaust port is not the same
heads so your car is not down.
