Is this the original radiator?
Old Jun 4, 2020 | 01:29 AM
Schfifty_5's Avatar
2003 E55 AMG
I need assistance verifying if this radiator is the original Valeo radiator on my 03 E55.
I’m hoping that it isn’t. I see numbers on the far right look like it could be the build date (17/04/06). Does anyone know if that’s the case? Thanks!
Old Jun 4, 2020 | 12:55 PM
equitiesguy's Avatar
Mercedes CLS 55 AMG
Any particular reason you need to know? Usually radiators are only a consideration if it's clogged or leaking, at which point you're replacing it anyway.
Old Jun 4, 2020 | 12:59 PM
Mercedes CLS 55 AMG
I just checked my photos from when I replaced mine and none have any shots of the date itself. Sorry man.
Old Jun 4, 2020 | 01:43 PM
coupesedan's Avatar
CLS55
03 E55s have faulty rads that dump coolant through the trans heat exchanger.
Old Jun 4, 2020 | 03:10 PM
GinDistiller's Avatar
2019 M5 Comp, 2005 Ariel Atom 2
Looks updated based on the part number, see this thread:
https://mbworld.org/forums/e-class-w...rt-numner.html
Old Jun 4, 2020 | 04:14 PM
Mercedes CLS 55 AMG
If I owned an E55, I would jettison the Valeo radiator regardless and replace it with the Behr.
It's the one and only disadvantage of the CLS55 --- we only can use the Valeo because of the changes to the transmission lines.
Old Jun 4, 2020 | 05:56 PM
Schfifty_5's Avatar
2003 E55 AMG
AFAIK, The updated Valeo radiators don't cause any issues. I would like to eventually change it out to a Behr but now that I know it's an updated Valeo, I don't need to rush. Thanks guys!
