Exhaust Manifold & tubing question
I'm going to weld the flange and see how it holds up. I was curious when it comes to re-assembly: would it be easier to put the manifold first, then motor mount, or the other way around? When I was removing stuff, I took out the manifold first, then motor mount. But thinking about it now, maybe it would have been easier to take the motor mount out first, since some of the bottom manifold bolts were tricky to get to.
Second question: with the exhaust out of the car, I'm thinking about doing secondary cat and resonator delete. I can't really get to measuring it right now, but I was wondering if anyone knew what size the piping is. I was thinking to order the stuff as soon as possible.
Thanks.
Buy this tool to make your life a little bit easier when replacing the motor mounts
The driver side is a bit fiddly to do, I made a video to see how you can shimmy the mount out (and back in hehe)
On my '99 E55, I literally had to unbolt the motor mount bracket from the engine block to remove one bolt because I was not aware of the nifty little extension wrench in the photo that Andy supplied above. This may apply to your engine but I cannot confirm yea or nay.
And here is why you remove all jewelry when working on the vehicle:
https://www.reddit.com/r/Justrolledi...ven_if_its_at/
Also, stock W211 E55 manifolds are no longer available new. I purchased the last passenger side manifold available in the world...as much as it cost I might have been better off going with long-tube headers.
For that one nut at the motor mount I think I should be able to use a long 10mm box end wrench. Ive been spraying the nuts down with PB Blaster and Liquid Wrench for a week now and got some of them loosened already. My fear is snapping a stud then i'd be screwed. I never replaced an exhaust manifold before. Couldnt reach the nuts so bought a cheap borescope and straw extensions for the penetrating oil cans which works great.
I was about to place aftermarket PLM style headers, but they didnt fit
