alternative for Mobil Jet Oil 2?
Old Feb 23, 2021 | 11:46 PM
ls1_mast's Avatar
w220 S55 AMG 2004
Question alternative for Mobil Jet Oil 2?
i cant get Mobil jet oil 2 at where i'm so i'm looking for an alternative .
from what i read , some suggested GM or AC Delco supercharger oils but as far as i understand Mobil oil jet2 is a turbine oil (which means it can handle extreme temps and oil expansion )
any suggestions for alternative oils ? bp 2380 is not available too
Old Feb 24, 2021 | 04:28 PM
Fountain35's Avatar
Where are you that you cannot purchase Jet II?
Old Feb 25, 2021 | 12:49 AM
CDC55AMG's Avatar
CLS55AMG
Mobil jet 254 is what I use in the supercharger. It's the latest generation (3rd) to jet ii oil and has increased thermal stability and degredation resistance. Can you get this Mobil product?
Old Feb 27, 2021 | 04:32 AM
AgSilver's Avatar
2004 E55,1969 300SEL6.3,2011 ML350 BlueTec Diesel,2005 ML400 CDI
https://www.aircraftspruce.com/catal...All%20Products
Old Feb 27, 2021 | 05:06 AM
ls1_mast's Avatar
w220 S55 AMG 2004
thanks for ur replay i ordered the 254 and waiting for it hopefully they wont stop it in the customs.
Old Feb 27, 2021 | 11:25 AM
CDC55AMG's Avatar
CLS55AMG
I apologize, I double checked my last fluid order and it was Mobil Jet Oil 387 which is the fourth generation product and a replacement for Mobil Jet Oil II and 254 which was the second and third generation product.
254 will still work just great so no worries but I am sorry i did not give you the most updated information.
Old Feb 27, 2021 | 11:30 AM
CDC55AMG's Avatar
CLS55AMG
https://www.aircraftspruce.com/catal...ljetoil357.php
Old Feb 27, 2021 | 01:50 PM
ls1_mast's Avatar
w220 S55 AMG 2004
no need to apologize man , it was a good advice. i googled both and as per as the data sheets , 254 is a great choice .
Old Feb 27, 2021 | 06:55 PM
oneslow55's Avatar
E55 amg
Truth is no one really knows what supercharger oil is used..I got a hookup in germany with the real oem stuff but it comes in a special bottle
Old Mar 1, 2021 | 06:22 PM
cdk4219's Avatar
95 SL600
Goose grease or snake oil, that’s what I’ve heard. I do spend lots of time concerning myself about possibly administering the incorrect lubricant to all of my vehicles, but in the end I believe they aren’t that much different. I need to buy a car and just throw caution to the wind and fill everything up with a 10w40 and see how long it all lasts. I would drain the antifreeze, flush and fill with green generic and tap water. Or flip it and fill all with dextron atf and see what happens either way.
You definitely hear the horror stories about possible incorrect fluids, but this seems to be a black magic area, where nobody really knows, but the manufacturer says you should use this.
The flip side finds guys running 300,000 miles on whatever oil and filter was on sale at the time and changing it regularly.
Old Mar 2, 2021 | 12:33 AM
ls1_mast's Avatar
w220 S55 AMG 2004
lol i had the same idea before and i would agree with u to a certain extent . i believe that any ATF will probably work for ant transmission, any engine oil will work for any engine just fine . as long as you are not pushing that mechanical part to its limits . and that is why those generic standard works for most of the non performance cars . because most of those car owners never push is to its limits or moded there cars. and who ever do push it while using those generic standards, there parts tend to fail .. but in those performance cars everything is a bit more sensitive than usual... same as horse power ... u might need 100HP to get to 150KM/H but u need 500 HP to get to 300KM/H and 800 to get 350KM/H so u get the idea .
