VRP pulley / tune
Old Apr 6, 2021 | 01:21 AM
rusbel's Avatar
2006 E55 - obsidian black, all options except pano roof - gone but not forgotten
VRP pulley / tune
Thinking of doing a couple of small mods to my stock 2005 E55. Want to install an 80 mm VRP clutched pulley and their Eurocharged tune. I did proactively replace the stock IC pump with the Bosch 010 ( though I feels like the car actually heat soaks faster now for some reason ). Would I need to split the cooling for these mods? I don't track the car. This would just be for some extra oomph on the street.
Also, what size belt should I get if don't want to go the belt wrap kit route?
thanks!
Old Apr 6, 2021 | 06:09 AM
tw2's Avatar
tw2
You don't need split cooling. It doesn't help on the E55 like it does with the other supercharged AMG's. I know an 83mm uses the stock belt, sorry not sure about the 80mm.
Old Apr 6, 2021 | 04:56 PM
testknight's Avatar
CLS55
I'd suggest an upgraded heat exchanger. Mine I think is a PLM and was pretty easy to install. I don't really notice heat soak issues. I have the 80mm pulley w EC tune as well
Old Apr 6, 2021 | 06:47 PM
rusbel's Avatar
does the front bumper have to come off to install the heatexchanger?
Old Apr 6, 2021 | 06:49 PM
rusbel's Avatar
also, do you notice a difference between the 80 and the 83 mm pulley?
Old Apr 6, 2021 | 07:10 PM
tw2's Avatar
tw2
Yes you have to remove the front bumper but PLM is the easiest install. Yes you will notice a difference between 80 and 83. My personal opinion is that 83 is more than enough for the street but everyone is different.
Old Apr 6, 2021 | 07:58 PM
axelbel's Avatar
2005 E55
I just installed 80mm VRP pulley, UPD belt wrap kit, PLM XL heat exchanger and did split cooling just in case. I have Race IQ tune and it feels more that enough power for me. No heat soaking but trying to battle traction now. Will probably try installing Wavetrac LSD to help with that.
Old Apr 7, 2021 | 09:58 AM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
We have the complete bundle start up power kit and over 30 supersized heat ex changers in stock.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Apr 7, 2021 | 01:23 PM
UncleBenz55's Avatar
W211 E220, W211 E55, W203 C55
Did you bleed the intercooler water circuit, after changing the pump?
Old Apr 8, 2021 | 10:52 PM
M5 LOL's Avatar
05 E55 (06 E55 RIP)
honestly, do LTs first. 40whp and youre set up down the road with no detonation issues with higher boost.
Old Apr 28, 2021 | 11:23 PM
rusbel's Avatar
I live in Illinois where we have to pass emissions...unless I do LT with cats?
Old Apr 29, 2021 | 05:04 AM
tw2's Avatar
tw2
I have LT's with cats. Definitely smells much better than cat-less.
