W211 Mult-CD changer door / How to make it function after updating head unit?
Old Aug 1, 2021 | 11:03 PM
MJBelcher500's Avatar
2006 E55
I just replaced my head unit with an updated Android unit. While that was a bigger "challenge" than I had hopped for (due mainly to a faulty unit, not the actual install), I am trying to figure out how to make the multi-CD changer door motor function. It appears that the head unit must have had something to do with its operation. Ultimately, I want to replace the CD changer with the "cubby", but I need to make sure I can get the door to function before I order it. I have searched around and have not found a definitive answer on this. Any help is appreciated.
As a side note, I purchased the Android 10 / PX6 from https://www.aliexpress.com/item/3279...404e4c4deukfO1 If anyone has purchased one of these and is struggling, feel free to contact me. I have hours of working on mine including replacing the amplifier chip and modifying the main processor connection. It's working well so far now, but it was a battle.I am pretty familiar with the inner workings at this point.
Old Aug 2, 2021 | 07:01 AM
Hrvstr1's Avatar
2002 S430 and 2005 E55 AMG
Cd changer
Here ya go.
Old Aug 2, 2021 | 11:53 AM
2006 E55
Originally Posted by Hrvstr1
Thanks for the link!
I was hoping there was a way to make the stock switch function the way it previously had. Any idea as to whether this is even possible?
Old Aug 2, 2021 | 12:57 PM
Hrvstr1's Avatar
My understanding is that it is not possible because it’s tied in with the rest of the system.
Old Aug 2, 2021 | 01:14 PM
mbmg's Avatar
2004 E55
It's possible but you'd have to either change your MOST box to an Enfig SRWH-W211 or just add it to the CAN system w/o connecting it to the fiber optic loop. If you do the later it may interfere with your audio steering wheel functions.
Old Aug 2, 2021 | 01:33 PM
2006 E55
Originally Posted by mbmg
It's possible but you'd have to either change your MOST box to an Enfig SRWH-W211 or just add it to the CAN system w/o connecting it to the fiber optic loop. If you do the later it may interfere with your audio steering wheel functions. https://youtu.be/zJALScfHdBI?t=30m57s
It was actually working without being connected to the fiber optic loop. A previous owner had installed a Mobridge Bluetooth unit and disconnected the fiber optics from the CD changer. The door still opened as expected. It's odd that every other control on that panel still functions other than the door button. Why is that control the only one that loses functionality?
I have both a fiber optic decoder and CAN Bus module. All of the steering wheel controls work. Is there something special about the one you linked to that resolves the door issue?
Old Aug 2, 2021 | 01:48 PM
mbmg's Avatar
2004 E55
Correct. I don't use the fiber optic system for audio in mine and I removed my cd changer and put the storage box in it's place. It must work off of the CAN system. Yes, the one I listed has the CAN coding for the cd door to work like oem.
Old Aug 2, 2021 | 02:08 PM
2006 E55
Thanks again.
I found this:
I have reached out to the guy to see what price and availability are. It might be a cheaper option. I'd rather not have to purchase the other kit as I do not need most if it.
Old Aug 2, 2021 | 05:04 PM
2006 E55
Originally Posted by MJBelcher500
Thanks again.
I found this: https://www.youtube.com/watch?v=zrIhHezPeCw
Update: For what its worth, I head back from the guy that makes the emulator that allows the CD changer door to work using the original button. They cost $60 each and shipping is $25. I believe they are coming from Russia. It is certainly more expensive that installing a remote relay, but it's definitely a cleaner/easier option.
Old Aug 3, 2021 | 09:06 PM
Jones77's Avatar
E55 AMG
Can you post results of this emulator once you receive it? Sounds like an elegant solution and I would definitely purchase one if it works.
Old Aug 3, 2021 | 10:59 PM
tw2's Avatar
tw2
I tried to make mine work. I followed some instructions on youtube years ago but it didn't work. I am very keen to see how this one works out. I reinstated the wiring for the electric motor but that wasn't enough.
Old Aug 4, 2021 | 05:59 PM
2006 E55
I am not sure yet if spending that much money makes sense to get it working. If I do order one I will start a new thread and let everyone know how it goes.
Old Aug 4, 2021 | 06:01 PM
2006 E55
From what I understand the door is looking for a CAN bus message to allow it to function. I am guess that the module that is being offer simply injects that message into the bus so that the door is enabled.
Old Aug 4, 2021 | 08:23 PM
tw2's Avatar
tw2
I assumed the same thing. In theory you can plug it into the bus anywhere in the car I would imagine. I used one in the foot well for my steering wheel controls module.
Is there a link to the module or website to order?
Old Aug 4, 2021 | 08:55 PM
2006 E55
That makes sense. I could mount it near the CAN bus junction box below the glove box and not need to stuff it under the head unit. Thanks for the itdea.
The guy is reachable via WhatsApp +374 91 190566. You can message him through YouTube, but he will then ask for you contact him via WhatsApp. There appears to be a discount on unit and shipping for orders of more than 10 pieces. Might be something for a group buy.....
Old Oct 4, 2021 | 12:51 AM
E63007's Avatar
07' E63
Count me in for one and soon as I’m getting ready for a complete Android Component Stereo install myself!
Old Nov 29, 2021 | 02:59 PM
jgnar's Avatar
w211
After a long search for how to enable the CD-changer compartment door after installing an aftermarket stereo, I found this thread, which eventually lead me to a german guy, that sells a similar emulator as described by MJBelcher500 in post #8. He has a site schlauhaus.biz and also an ebay store for his stuff. You have to search for "w211 kinematics adapter" in ebay or on the website. I ordered one from ebay, and can confirm, that his adapter indeed makes the CD compartment door in my 2005 W211 move again. Originally my car had a basic Audio20 CD head unit without CD-changer and without amplifier. The kinematics adapter has a nice 3d printed enclosure that attaches nicely to underside of the CDE changer compartment box. It also has detailed installing instructions, and even a tool to attach the wires in tight conditions. One caution though, if you have Alpine ilx 702d head unit installed, as I do, then you still cannot use the compartment, as the compartment door binds against the protruding buttons that the Alpine unit has under the screen. Bummer! Now I have to find a good Carplay head unit with a flat front.
Old Nov 29, 2021 | 03:07 PM
2006 E55
Thank you for posting this. This one looks to be a cleaner solution to the problem than the one I posted. It still seems a bit overpriced for what it does. That said, I may still order one to make use of the space behind that door.
Do you have an eBay link? I searched, but could not find it.
Old Dec 1, 2021 | 09:47 AM
mbmg's Avatar
2004 E55
https://www.ebay.de/itm/274300795227
Old Dec 1, 2021 | 02:13 PM
jgnar's Avatar
w211
Yes, that's the one I ordered. I was also able to modify the head unit frame to move it a little more into the dash and now the door works without binding. I agree, that the adapter is a little pricy, but it works well and was easy to get, so I am happy!
Old Dec 1, 2021 | 02:22 PM
2006 E55
I'm talking to the guy in Germany now about ordering several and possibly 3D printing the enclosures myself. If I can get the pricing to work out I'll start a new post with the cost to forum members.
Old Jan 3, 2022 | 04:42 PM
2006 E55
I have spoken to the German manufacture of the modules that reactivate the CD changer door. I am considering ordering a batch of these modules to make them available to the forum members. How many of you would be interested in ordering one if I have them available?
Old Jan 4, 2022 | 03:25 AM
AMGPilot's Avatar
2004 E55
I'll take one
Old Jan 4, 2022 | 11:37 AM
E63007's Avatar
07' E63
I’ll buy one as well!
Old Jul 5, 2022 | 11:38 AM
dw00's Avatar
2003 C230 Kompressor
I just encountered this issue with an aftermarket install of android carplay headunit (Atoto A6 PF) on my son's 2004 E320 with HK sound. Son and I installed HU with Xtrons fiber optic decoder and fiber by-pass loop at CD changer to maintain MOST network.
Need input on possible economical solution. Would a DPDT switch wired directly to the motor in the manner of the video in post #2 work? After all, isn't the double relay module in Panzer's video emulating a DPDT switch with added wireless control? I have zero experience with DPDT switches but thought maybe a simple DPDT push button style switch could be mounted discretely to provide power on first push to open door and push again to reverse polarity/close door.
On the CANBUS front, isn't this just a line of code in the canbus giving the door permission to operate? Could this be added to canbus boxes on the market? I know some of the nicer modules like PAC and AXXESS are USB updatable. I doubt this piece of code is a priority for canbus decoder people given that the CD door is a small subgroup of the w211 family. Maybe that RND-ASH fellow over in the UK addressed this in his canbus programming.
