I greet you. as far as I understand, you did not understand the meaning of my design at all! my design is universal compared to yours. and you are mistaken when you say that the compressor does not turn on in the city. the compressor turns on. because this machine rules to press the pedal and it doesn’t matter where are you in the city or on the highway. and I tested the tank with the temperature sensors that I have installed. and the experiment showed that when a lot of liquid heats up in the tank and the entire system, so that it cools down, it takes a long time to drive in the heat so that the car can effectively accelerate again .it is physics - a lot of water heats up for a long time and also cools down for a long time. and you want to prove to me the opposite. your tank for city driving has a drawback. and my homemade tank is universal. when driving around the city, the volume of liquid in the tank does not participate in the circulation. in other words a smaller amount of water participates in the circulation, which means it cools down faster. This is what the city needs to cool down faster. And I achieved this very simply - I'm an outcast I made a tank in which you can connect the supply and return inside when necessary. and when necessary, I disconnect one hose from the tee with the fingers of one hand - and that's it! now the circulation goes through the tank. and you can go to the races taking ice with you. so you they concluded early on about my custom tank, my friend. Better think about how to make your tank universal.!
Reason: Ощибка
