Swapped OEM Air Springs for Arnotts- Not Filling
Old Jan 27, 2022 | 12:27 PM
dvrmstrng's Avatar
06 E55 AMG
I have searched and read far and wide, looking for any additional ideas.
Prior to this install the car would raise as lower as normal. Ride height was lowered via STAR however the “raise vehicle” button and compressor worked fine. My only issue was the rear and failing to maintain ride height when parked for more than a few days. When I removed the stock bags the rear passenger side was damaged and barely held any air. As suggested by Arnott both air springs were replaced at the same time.
I did the swap using the FCPEuro video as guidance and everything went perfectly. I have triple checked my Voss fitting and electrical connections and everything is fine. The compressor still kicks on and raises the front of the car but I am getting zero air to the rear springs.
I have lowered the car to slightly below ride height, supported by a jack, unplugged the battery to reset things, and when I fire everything back up I still get nothing at the rear bags, no hissing no inflation.
I have contacted both of my local Indy’s and they said they have to see the car to do anything.
Could this be the result of the car being lowered via STAR prior to the swap? Could I have damaged the ride height sensor somehow?
I appreciate any feedback.
Old Jan 27, 2022 | 01:11 PM
hachiroku's Avatar
SPONSOR
2007 Mercedes E63 AMG
with proper diagnostic tool, you should be able to actuate each valve and monitor its status. can't troubleshoot without looking at electronics for functional testing.
__________________
-BARRY
​​​Follow us on instagram @eightysixtuned
https://www.eightysixtuned.com
Old Jan 27, 2022 | 02:07 PM
GinDistiller's Avatar
2019 M5 Comp, 2005 Ariel Atom 2
Did you do the lowering via STAR, or a shop? If you did and have a STAR system that is the first step, checking those values and forcing each corner to add air. If you don't see if you can find someone who does - where are you located?
I can't see how the modified values would affect refill like this, all it is is a little trickery in the level sensor baseline. The rears share one sensor, I think the fronts each have one, so you could have a sensor issue since both rears aren't inflating, but you won't know for sure until you see its value in STAR.
I'll be following this thread, I'm also lowered via STAR and need to replace my rear bags soon, I just keep putting it off...
Old Jan 27, 2022 | 02:39 PM
dvrmstrng's Avatar
06 E55 AMG
Yeah, I’m trying now to locate someone near me that has the star diagnostic tool so I can attempt that. I can’t take it to the shop because it lays frame. I don’t even think I would be able to get the Jack out from underneath it at this point.
It was lowered via star before I got it. Don’t have any fear about replacing the rear bags, I’m a super amateur mechanic and I did it myself with no issues other than this refill problem. I am in Delaware.
Old Jan 27, 2022 | 03:18 PM
No fear, just laziness . I have a lift at home, and STAR, wish I was closer and could help!
You probably checked, but I'd just make sure the rear level sensor was reinstalled in the correct orientation (and plugged in).
Old Jan 27, 2022 | 03:42 PM
dvrmstrng's Avatar
06 E55 AMG
So lucky. I did this in sub 30 degree weather, no lift, no heat.
The single rear level sensor on the E55 is near the rear diff. I didn’t mess with it during install and a visual inspection today looks fine. Do you think there’s some way it got tweaked during this install?
Old Jan 27, 2022 | 06:02 PM
TempeAMG's Avatar
2007 e63 amg
I had the same issue with my 07 when I did the back air bags about 3 yrs. ago. I replaced back air bags with Airnotts and when I first started the car, the front rose but the back didn't. I pushed the raise car button and the entire car rose to its full height and when pushed again it lowered to its ride height and everything worked.
You might give it a try if you haven't yet.
Old Jan 27, 2022 | 06:05 PM
dvrmstrng's Avatar
06 E55 AMG
I’ve tried that several times with no luck. No hissing at the bags and no error messages. Did you have the car on the ground at that point or in the air? I read in an old thread somewhere that when the bags were disconnected the car may have thought there was a leak and now it won’t send air to the rear. I need to somehow reset that if it’s the case.
Old Jan 27, 2022 | 06:11 PM
TempeAMG's Avatar
2007 e63 amg
I had the car on the ground, but had most of the body weight supported by jacks.
When you raise the car does the front raise at all?
Old Jan 27, 2022 | 06:16 PM
machild's Avatar
2006 CLS55 AMG, 2005 SLK 350 AMG
That's another Star issue. Find one and you should be able to get all your issues sorted out.
Old Jan 27, 2022 | 06:21 PM
dvrmstrng's Avatar
06 E55 AMG
Yeah that’s what I did the second time. Compressor kicks on and lifts the front as designed.
Old Jan 27, 2022 | 06:22 PM
dvrmstrng's Avatar
06 E55 AMG
Finding one is proving to be difficult! Still trying though.
