Dirty fuel injector Cylinder 8
Old Mar 1, 2022 | 06:32 PM
SlavShreds's Avatar
2006 CLS55
CLS55 118k miles. Stock except PLM XL HE and Bosch 010 pump. Did my MAP sensor first thing this morning; what a way to start the day. Got done without removing supercharger or the left engine hoist. Had to remove fuel rail and upon further inspection I noticed the injector on Cyl. 8 was, of course, noticeably dirty while the others looked ok. Looking at the attached pictures, would you say I'm due for new injectors anyway due to mileage? If I am due, should I stick with stock or go 550cc? I have no info on whether they have been done or not by the previous owners. Also, this is my daily so the only mods in my future are LTH and a slightly smaller pulley (in reference to type of injectors to buy). P. S. Why are there 4 "tabs" on the orange ring of clean injector and 2 tabs on dirty one?
Clean(ish)
Dirty
Old Mar 9, 2022 | 11:03 AM
SlavShreds's Avatar
2006 CLS55
Any input? Is this a stupid question? If so, let me know and I’ll appreciate it.
Old Mar 9, 2022 | 01:23 PM
Fountain35's Avatar
If the injector is dirty you can send it out or see if there is a local shop that cleans them. (RC Engineering does good work).
https://www.rcfuelinjection.com/
If you are going to do it, I'd send them all to get cleaned. You can also just replace the one clogged. As far as upgrading to larger injectors it is required after you hit a certain level of modifications, I believe it's around 600 hp but I'm not sure, ask in a separate thread. Birdwell or others would know. You could even call Eurocharged or a tuner shop.
Old Mar 9, 2022 | 01:52 PM
Fountain35's Avatar
Not a stupid question, very good one actually.
Old Mar 10, 2022 | 12:54 PM
SlavShreds's Avatar
2006 CLS55
Do you think the dirty one is clogged? It hasn’t popped codes and I also haven’t flow tested them. New 550cc’s are only about $80 more than the cleaning service so I’ll do some more research before the decision. I’ll send a PM to Birdwell as I’ve seen his name on here many times. Thanks!
Old Mar 11, 2022 | 02:38 AM
Fountain35's Avatar
Can't tell by looking. If you think it's clogged just send it in and get it cleaned. Might try yourself and see if it's clogged.
Old Mar 12, 2022 | 03:47 PM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
FWIW, whenever I am rebuilding an engine, I have the injectors cleaned and flow tested.
Old Mar 12, 2022 | 04:58 PM
tlambert's Avatar
2005 E55 AMG
Barry who are you using?
Got a link to a company you trust?
Old Mar 14, 2022 | 01:32 AM
Fountain35's Avatar
R/C Engineering is good I have used them for over 25 years. They give you before and after cleaning flow results and pattern. It's easy stuff.
Old May 25, 2022 | 07:42 AM
nd-photo.nl's Avatar
2005 CLS55 AMG W219 C219
Its dirty on the outside due to the rubber seals not closing off properly. There are service kits for this. From your pics they look like the units I had on my Volvo S80, where I serviced them myself. I purchased the servicekit on Aliexpress, including a special tool to remove/replace the injector baskets (see last pic).
Old Jun 13, 2022 | 01:12 PM
SlavShreds's Avatar
2006 CLS55
Awesome, I will have to source one for myself as well. Thank you its much appreciated
Old Jun 14, 2022 | 04:43 PM
I will save you the search I checked my previous Aliexpress orders and I bought this set: https://aliexpress.com/item/32562858425.html
Old Jun 14, 2022 | 04:56 PM
SlavShreds's Avatar
2006 CLS55
You da man! Thank you again
