Questions- oil cooler fan & IC water pump
1 Post
Mercedes C320 300CE 560SEC
These two things pop up as nowhere to be found on a C320 wagon. How are these powered they go to the front SAM and what are the set points or when are they turned on/off
Thanks,
Steve
Thanks,
Steve
2006 CLS55 AMG, 2005 SLK 350 AMG
Edit: Oil cooler fan is fused on #60 and relay R in the front SAM on the 211/219 platforms
1 Post
Thanks,
When I dove into the water pump thread I found it kind of interesting that the water pump just runs with key on! The other thing to consider is do either of these cause a CEL My oil cooler has a line that is stuck and the bung is not in great shape. An aftermarket or different form factor oil cooler may be a better fit? I am asking these questions here because this forum has the experience with this drivetrain. I have two cars with M-120 V12's naturaly aspirated their oil coolers are passive. A friend with an M-120 in an R107 has no oil cooler and temps are not an issue. I do intend to use an engine oil cooler with a fan. Are there issues with oil temp in the E55 in hot weather? I have a house in Woodland Hills, Ca. that area see's 110+ days often in the summer.
In my W203 wagon the cooling accessories may not be in the same arangement or location as a W211. For example the engine oil cooler may live in the left wheel well. I am going to split the cooling system for the engine/ inner cooler with perhaps additional heat exchangers. Another cooling item I am considering is a stand alone transmission cooler. I don't know how big an issue the internal trans cooler is in the E55 today? This transmission shows no signs of coolant contamination.
Steve
Steve
Why do you need an inter cooler for a normally aspirated engine, and split cooling for again a normally aspirated engine? Intercoolers are for forced induction, and air to oil as well as air to transmission coolers are more than adequate for any c320.
Thanks,
Steve
Steve
1 Post
Thanks for the info and your install looks very clean.
After reading a lot of stuff on the pump and heat exchanger front and, faced with limited real estate in the C class I am leaning towards a killer chiller system. The C has the battery in the right firewall under the fresh air filter and as a wagon the floor in back is not configured to do a rear battery. There is precious little space for a tank anywhere so I am going to explore the fender voids. The washer bottle in in the left headlight area now, looking to relocate that for a bit of flex space. As I recall the supercharged M113 is a mere inch or so from the fan when installed in a W203 that is not using a long nose ala CLK or C55 so everything is going to be a snug fit!
Steve
Steve
