M113k Belt Wrap Kit - with or without bracket?
Old Feb 15, 2023 | 07:32 AM
nd-photo.nl's Avatar
2005 CLS55 AMG W219 C219
I was looking into Belt Wrap Kits (BWK) and I noticed I see a lot of kits with the bracket (for reinforcement purposes probably) but I have also seen some kits that do it without the bracket.
We all know this solution. Pictures are from @VictoryRoadPerformance website
I can imagine that without a bracket is much easier to do service where you need to remove either the supercharger or serpentine belt.
Some information about the "bracketless" BWK, its translated from German
What distinguishes my solution:
- My kit doesn't stand out
- Not one of the screws is loaded in shear, bending stress is kept within limits
- The screw on the double deflection pulley - which is already subject to a borderline load - is not additionally loaded
- If the holder is installed correctly, it is impossible for the additional deflection roller to run skewed (!!)
- Nothing needs to be dismantled to change the belt.
In the last picture is the "Shardul Metha", "VRP", "DTK" kit.
In my opinion, the kit has 3 major disadvantages:
1. The screw of the double deflection pulley, which is already heavily loaded, is even more heavily loaded.
2. The many tolerances can cause the idler pulley to misalign, which will manifest itself as damaged or shredded belts.
3. The kit must be almost completely disassembled to replace/remove one or both belts.
I would love to hear your ideas about this!
Old Feb 15, 2023 | 08:55 AM
nemiro's Avatar
2004 Crossfire (w/M113K), 2008 Crossfire (w/M156), 2008 ML63, 2018 AMG GT
As someone who has a BWK on this engine in a really tight engine bay (R170), I can tell you that serviceability is a real issue. On the other hand, there is little doubt that the bracket adds stability to the entire system. I am sure the materials are strong enough to support the added pulley without the bracket, but the bracket supports both pulleys by minimizing deflection.
Old Feb 15, 2023 | 03:15 PM
E55Greasemonkey's Avatar
This place is a joke.
With the left side of the bracket notched it's an easy belt swap by simply leaving in place and loosening both bracket bolts and swivelling the bracket upwards. My original Shardul kit didn't have the notch so I added it later on.
Old Feb 15, 2023 | 03:20 PM
nemiro's Avatar
I have a Creative Steel kit. It does have the slot. It's still impossible to change that belt without removing my upper core support and pulling the cooling fan out. Sounds trivial until you understand how much work is involved with that. If I moved like the wind, and had power tools, I might be able to change the SC belt in a little over an hour. In the dark, raining on the side of the road? Yeah, not funny.
Old Feb 15, 2023 | 07:36 PM
SICAMG's Avatar
2005 e55 AMG
I run a 20lb tensioner and that cross brace adds a lot more strength and stability in my opinion.Mine is a Creative Steel and I notched it and modded the idler bracket for more wrap around the blower pulley and also added a 100 mm idler pulley.
Old Feb 16, 2023 | 04:40 AM
Thx for the input!
Would be cool if @VictoryRoadPerformance (or another creator) is able to comment on the brace and the function behind it
Old Feb 16, 2023 | 07:12 AM
SICAMG's Avatar
2005 e55 AMG
Nemiro yea my fan stays in place for belt removal.
Old Feb 16, 2023 | 07:35 AM
In E-class or CLS you probably have a bit more room for belt removal. I also don't have to remove the fan for supercharger and/or serpentine belt removal
Old Feb 16, 2023 | 10:08 AM
nemiro's Avatar
Yeah, it's pretty tight in there. This is before I added the BWK, which made a belt replacement completely out of the question. At this point I was running a stock lower and a 77mm upper pulley. I have since switched to a 180mm lower and a stock upper, so BWK is a little less necessary.
Attached Thumbnails M113k Belt Wrap Kit - with or without bracket?-20210911_105605_-resized-.jpg   M113k Belt Wrap Kit - with or without bracket?-20210911_105602_-resized-.jpg
Old Feb 16, 2023 | 01:32 PM
Yes, that is way less space compared to this
Old Feb 17, 2023 | 05:54 AM
StuttgartAMG's Avatar
E55 AMG (W211)
Hi.
Im the vedor of the second "German" BWK.
A friend and I considered the "American style" BWKs and we (automotive engineers) found some vulnerabilities.
- The serviceability wasn't really required at that style. You need to pull of the front bracket to service the belts.
- Tolerances in production were not sufficiently considered, so the belt can (not neccessarily) run at an angle and can be shredded (see several posts in different forums and facebook groups).
- the additional force on the doubler idler pulley screw did not please us.
- shipping to Germany with customs and VAT were very expensive,
so we devided to design our own BWK considering all the vulnerabilities of the existing design.
Old Feb 17, 2023 | 08:54 AM
nemiro's Avatar
As serviceability is a major obstacle for my application, can you give a link to your BWK that will not require the bracket?
Old Feb 17, 2023 | 01:40 PM
@nemiro as requested
https://www.ebay.com/itm/124940732322
https://www.ebay.com/itm/333999827935
https://www.ebay-kleinanzeigen.de/s-...81737-223-8097
Old Feb 20, 2023 | 01:25 AM
E55 AMG (W211)
this is the original one from me.
the first link is a copy of my design without considering the tolerances.
Old Mar 24, 2023 | 06:52 PM
Streetsoffire's Avatar
W216 CL65, W219 CLS55
Does anyone know the size of the belt on the belt wrap kits? Would the Gates (green belt) K080526HD work with a 76mm supercharger pulley?
Old Mar 28, 2023 | 06:24 PM
Lee Gilchrist's Avatar
03 E55 AMG
BWK
I can tell you from first hand experience. I have two e55s one with a belt wrap kit and one without. Both have the same clutched 77 mm pulley with tune and I DON'T HAVE belt slip on neither one. I did a lot of searching before purchasing my last super charger belt when I recently installed a 77 mm pulley.
QUOTE=nd-photo.nl;8722856]Thx for the input!
Would be cool if @VictoryRoadPerformance (or another creator) is able to comment on the brace and the function behind it[/QUOTE]
Old Mar 28, 2023 | 06:52 PM
BMW Owner's Avatar
e55 AMG
[/QUOTE]
Can you share your research?
Old Mar 28, 2023 | 07:05 PM
Also what belt are you running? Im currently on the Gates RPM which I like very much
More pics in my thread > https://mbworld.org/forums/c219/8443...ml#post8653485
Old May 23, 2024 | 03:54 AM
Bab26's Avatar
E55 w202 2.3 turbo
Bwk
Hello do you still sell your bwk version?
Old Apr 14, 2025 | 10:14 AM
MKDub's Avatar
R129 SL500 1994, W211 E55 AMG Wagon 2006
Would also like to know?
