Sudden Camber Wear/ Rubbing in Rear
Old Feb 20, 2023 | 07:52 PM
Andres Morejon's Avatar
2005 E55 AMG
Hello, as the title says my 2005 E55 has developed quite some wear in roughly 3000 miles. I am talking about the passenger side rear. The tire has maybe 4-6k miles on it. The wear is so extreme it's almost as if it's scraping on something. It tracks straight and no vibrations even at 90mph. The tire is a continental extreme contact dws06 plus. At a glance the car isn't slammed and if it were air suspension I thought both sides would be the same since the struts are linked in the rear. Anyone had similar issues or thoughts as to why this happened? I dont do burnouts and I hardly ever give it over half throttle. I drive like a grandma. Any help would be huge. Thanks!
Old Feb 21, 2023 | 04:17 AM
nd-photo.nl's Avatar
2005 CLS55 AMG W219 C219
Wow that is extreme indeed. It should be something in the suspension/alignment. Even though the airsuspension share the same sensor in the rear, you can still have height differences (air spring leaks, connection leaks etc).
I would get it checked by a proper align shop and work from there.
Old Feb 21, 2023 | 08:22 AM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
I would suspect incorrect toe.
FWIW, I just recalibrated my suspension after replacing rear air springs; minimum ride height while remaining in recommended factory inclination angles put my rear fender rolls at 26 3/4" to 27". If yours are at 26" or below that would result in extreme negative camber.
Let us know what you find.
Old Feb 21, 2023 | 10:38 AM
Yuille36's Avatar
Veteran: Marine Corps
07 E63 AMG, 10 C63 AMG, 07 E63 Designo, 07 E350, 09 C300, 07 C230
One of the easiest ways to diagnose this tire wear, is to have an alignment done. This will tell you a lot of things: toe, camber and caster and they should be able to get you back within spec, before you buy a new set of rear tires.
If they can't, then you have worn out suspension components. I recently had an alignment done, after replacing my entire suspension with all new everything.
Old Feb 21, 2023 | 01:28 PM
Exactly this, but better explained than I did
Old Feb 21, 2023 | 02:27 PM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
Yuille36 is pretty knowledgeable and a former Marine. So... don't let him see your crayons because he will eat them.
Old Feb 21, 2023 | 02:36 PM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
Yuille36 makes very pertinent observations. For the rear I will say the toe is adjustable using the toe adjustment arm but the camber, assuming all of the suspension components are in good shape, can only be adjusted by raising or lowering the suspension. Obviously, you can get an aftermarket camber arm but I have never been happy with the few that are available out there.
Old Feb 21, 2023 | 02:45 PM
Yuille36's Avatar
Not a former Marine; Once a Marine always a Marine. But, I'm currently retired. And thank you for the acknowledgement that I'm pretty knowledgeable. That means a lot.
Old Feb 21, 2023 | 02:56 PM
Yuille36's Avatar
If you take another look at that tire, one would say that is extreme wear due to excessive camber, but a lowered suspension contributes to the wear. And tends to add even more camber.
I would check your rear thrust arm and torque arms. These are the two control arms on top of the rear suspension, that you normally can't see unless the cars is on a lift.
Old Feb 21, 2023 | 03:24 PM
tlambert's Avatar
2005 E55 AMG
Andres, post a pic of your car at its daily ride height.
Old Feb 23, 2023 | 04:27 PM
eightysixtuned's Avatar
W211 E63 AMG
for me...after a few alignments, replacement of parts for my adjustable arms, and dealing with tire wear, did learn that i pulled the subframe threads out of the body causing the entire subframe to shift back and forth causing increased tire wear. my last set of tires only saw maybe 3000 miles and are bald now.
