Cooling for Heat soak
If you have split cooling, a self bleeding system is quite easy to achieve. See the topic of @UncleBenz55 here: https://mbworld.org/forums/w211-amg/...ml#post8528716
Im running a slightly bigger intercooler with Bosch 010 pump, with wiring set to ignition. Car has stock power. More info & lots of pics here: https://mbworld.org/forums/c219/8443...ml#post8791081
