Dash Sensor (Ambient)
Old Sep 12, 2023 | 12:47 AM
Fountain35's Avatar
Is there a name and part number for this? I can't seem to be able to find it.
Thanks in advance.
Old Sep 12, 2023 | 01:13 AM
black06c230's Avatar
mgLipGD
Part
HVAC Duct Air Temperature Sensor - Mercedes-Benz (211-830-02-72)
How to replace
https://www.benzworld.org/threads/ca...ensor.2988819/
Old Sep 12, 2023 | 01:54 AM
Fountain35's Avatar
Thank you!
Old Sep 12, 2023 | 12:33 PM
nd-photo.nl's Avatar
2005 CLS55 AMG W219 C219
Its doable but a bit fiddly! Also replaced this not too long ago
https://mbworld.org/forums/c219/8443...ml#post8799942
Old Sep 12, 2023 | 06:40 PM
Fountain35's Avatar
What do those other two sensors do? Where are they located?
Old Sep 12, 2023 | 09:28 PM
bobgodd's Avatar
2004 E55
Any tips on this? I found the driver's side lower dash particularly fussy to remove when I tested on a car in the junkyard. I never did get the wiring off near the ignition cylinder; ended up cutting it.
Old Sep 13, 2023 | 08:47 AM
I only removed the plastic trim (2x torx bolts and round plastic retainer bolt in the back). I have pretty small hands, so after removing the trim I was able to sneak in there with 1 hand. The sensor needs 1/4 or 1/2 turn to remove it from the mounting point. After that unclip the electrical clip. If you are "handy", you can unhook the electrical clip first and then turn it to remove it from the mounting point.
There are 2 other temp sensors in the interior, 1 measures the temp of the aircon flow. Its pretty much in this location, but you dont need any tools to pry it out. Just wiggle it out.
The other one is in the Overhead Control Panel aka OCP, and uses the same design as the one below the steering wheel. Mine was broken (they all do), so I only replaced the thermistor with a new one. Some basic soldering skills is all you need.
https://mbworld.org/forums/c219/8443...ml#post8812111
Old Sep 13, 2023 | 09:48 AM
Fountain35's Avatar
I think you need to be a rubber man in a circus act to do some of these jobs.
Old Sep 13, 2023 | 01:57 PM
Fly over your car to me and I will do it, or fly me over to Virginia
Old Sep 13, 2023 | 02:55 PM
Fountain35's Avatar
Old Sep 14, 2023 | 02:13 AM
Fountain35's Avatar
https://www.youtube.com/watch?v=ViCJ3kKhFxo
Do you know the part number for the A/C evap temp sensor? If I’m going to play monkey I will replace them both. 🤪
Old Sep 14, 2023 | 06:16 AM
Should be this one: https://www.fcpeuro.com/products/mer...ehr-2208300772
Old Sep 14, 2023 | 12:51 PM
Fountain35's Avatar
Ordered!
Thank you!
Old Sep 14, 2023 | 01:09 PM
@Fountain35 You're welcome
