Suspension clunk?
It sounded almost like when you pop a bone or a clunk. When I would brake hard it would make the noise too. It also did the sound when I turned it fully to the right when I was pulling out of a parking spot but it did it only once. So I drove home carefully and jacked it up once I got home. The tie rod on the driver side was moving where inner and outer tie rod connect. The adjusting nut was so loose that I could move it with my hand. The bushing looked pretty bad and the wheel had play in it. So I parked the car and ordered the fcp euro tie rod kit. The tie rods ended up taking three weeks to deliver because of UPS delays. I installed them yesterday and took it for a drive. The alignment was pretty off. My esp malfunction message would show up after driving for a minute.
I searched it up and people said it was due to alignment. So hopefully that fixes that. But the main issue is THE FRICKIN NOISE IS STILL THERE. The same noise was still there. It still does the thump when I accelerate and let off. It also did it once when I was turning at a red light. I didn’t drive much because the alignment was pretty bad (about 4 miles). So I do feel pretty bad that I threw a part at it that wasn’t the issue but at the same time the old tie rod was going bad if not already bad. Do you guys have any idea what it might be. Possibly the top hat? The thing is my e55 is converted to regular springs. So I wouldn’t know if it could be that. All the bushings looked okay. Any input is appreciated. Please ask if you need any clarification I’m not too great at explaining an issue.
