What can cause piston Rings to go bad?
Mercedes E55
Hey folks, if you have seen some of my other recent threads, my e55 was burning oil like crazy and blowing white smoke.
had mechanic inspect engine and said it's the piston rings.
this engine set up only lasted 2 months, was burning oil from first month onwards.
what could have caused an engine (that was fully inspected to be working before it went in) to fail in such a short time? Car was mostly cruised, not thrashed. Is there a way to investigate and find root cause of such a quick failure?
Fully inspected meaning every piston was removed and checked. All rings and cylinder bores in spec......Nope !!
VERY few people know how to work on these engines so someone "looked" at the piston tops with no heads on it and put heads on.
The following 2 users liked this post by SICAMG:
HubTraum (03-05-2024),
Rallyboy383 (03-05-2024)
Mercedes E55
The smoke has gotten worse and worse..
At this point who cares. Your reading into " what ifs" and "what else"
It's under extended warranty like you said so it's their problem, not yours. Let them deal with it and fix it the right way.
2005 CLS55 AMG W219 C219
Also, don't mess around yourself if its their responsibility, as they can easily say: no we cannot support it anymore as you changed something yourself (ask me how I know
![Roll Eyes (Sarcastic)](https://mbworld.org/forums/images/smilies/rolleyes.gif)
1999 C43 AMG, 2005 E55 Wagon
Driving on bad rings can not only drastically shorten oil's lifespan, it also burns off huge amounts of oil. So unless you're topping it off with fresh oil every time you drive it, it can do damage to everything that requires clean oil.
SICAMG (03-09-2024)
Mercedes E55
Car was burning/leaking a TON of oil over 2 months. It went from burning 2L of oil per 1000 kms to around 1L per every 250 kms driven over the course of time (worsening over time)
Totals to around 15L put in over the course of 2 months. Total around 4000 kms of driving.
The mechanic (who assembled engine) top up 2L
another mechanic top up 4.5L
myself top up around 9L,
