"No CD Changer" - Again!@#&
Anybody else have this problem? Going out of warranty in 2005 ....
TJC
greetingz,
TJC
Dealer offered to diagnose problem for $350, plus the cost to replace radio and possibly CD.
A local auto stereo shop, CALIFORNIA CAR SOUNDS, INC 408 378 0409, looked at the car. They pulled the CD and tested it in another car, works OK. Tested fiber optic cable, works OK. Tested radio==defective. Raymond and his team at CALIFORNIA CAR SOUNDS rock. Smythe European sucks, basically they refuse to stand behind MB factory equipment.
I bought the car at Van Housen in Sacramento, when I lived in Folsom. Somehow, I cannot help but feel that Van Housen would have offered some sort of after warranty assistance as I am a local, delership-oriented maintenance conscience customer. I will NEVER recommend Smythe European for either MB/Volvo purchase or service. Further, I will move all of my auto warranty work to another MB dealer.
-s-
.................second issue is that those with the old startac phones seem to have this problem more often. The dealers explanation is the if the handset fails to sync properly, it will trigger a fatal error that prevents the radio from communicationg with whatever is connected to it. This is apparently what happened to my friends car. Her radio, Cd changer or cables did not need to be replaced.
Ted
TJC
On another note, I had another problem which occurs at/or around the same times...after washing and drying the car, I would usually listen to the radio while the car is off. Every now and then, the volume would just jump to MAX or down to low by itself. Any others have this problem? Not meaning to hijack the thread, just wondering.
.......you have to understand that these days there are really no mechanics or technicians for MB vehicles. What they simply do is to replace things. They hook the car up to a computer and replace whatever it is that the computer says is wrong. This works fine when your car is under warranty, but is very annoying when your warranty is over. I doubt very much that so many CD changers could suddenly go bad in Mb vehicles. You experience clearly shows that the CD changer is not likely to be the problem. The problem you have is that no body at an Mb dealership is going to know how to find out the problem. They will keep replacing things until they stumble at the answer by accident.
Ted
Not sure whether you want to do this.... at least somehow it fixed the problem or made it occur less frequently.I think the culprit is the CD retrieval parts (which pulls the CD from and put the CD back to the magazine).
At least if it doesn't fix your problem, you know why it kept giving you that error messages...... outside, it says "MERCEDES BENZ".... inside it says "MADE IN CHINA"
I have 02 E55 too and I have Comand and no CD changer. Was thinking about getting Cdchngr cos cd's keep being stuck on the eject and you have to grab them with fingers and pull them out ;-)
Anyone knows how to fix this?
Hope this helps.
