Dropped the E55...
Old 02-22-2005, 11:04 PM
MBAMGPWR's Avatar
W215 CL600
Dropped the E55...
I got my E55 back today after getting the car dropped. Ride quality is just as good as stock IMO and looks much better. LMK what you all think:
Old 02-22-2005, 11:13 PM
D-5
D-5's Avatar
2003 E55
looks hot!! which lowering module did you go with??
Old 02-22-2005, 11:17 PM
BoBcanada's Avatar
AMG
Wow that looks so SEXY! How did you do it?
Old 02-22-2005, 11:23 PM
vrus's Avatar
2003 E55 AMG
Awesome!! Ok.. Now.. Fessup and tell us which module you used.
Old 02-22-2005, 11:41 PM
Out Of Control!
JamE55's Avatar
Pimp!
Old 02-23-2005, 12:45 AM
AMG BLISS's Avatar
looks awesome. every E55 should be lowered, espcecially with 19's.
Old 02-23-2005, 10:43 AM
MBAMGPWR's Avatar
W215 CL600
No module. Took Peter B's advice and went w/ lowering links for the front and adjust the rear sway bar for the back. Easy to adjust and put back to stock if desired.
Old 02-23-2005, 10:52 AM
M5KILLR's Avatar
good man, glad i could help a fellow modder. now take some of the cash you saved and get to more moddin'
Old 02-23-2005, 10:54 AM
M5KILLR's Avatar
by the way, i originally bought 4 yet only needed 2. if anyone is interested in buying 2 (you only need 2) pm me. cost for me was $125 a piece. ill sell both for $150.
Old 02-23-2005, 10:58 AM
vrus's Avatar
2003 E55 AMG
MBAMGPWR,
One question though... At that height, what happens when you are on the highway and ECU attempts to drop the car an additional 0.4"??? Wont it be TOO low at that point?
Did you install the droplinks yourself?
Old 02-23-2005, 11:12 AM
MBAMGPWR's Avatar
W215 CL600
Originally Posted by vrus
MBAMGPWR,
I had my shop that I always go to do the drop. I've already taken it on the highway and I've had no problems with the drop. I've only had it done for 1 day, so I'm still deciding if this is my final height or not. I can get it adjusted in 15 minutes.
Old 02-23-2005, 11:16 AM
Fast55's Avatar
'06 E55, '05 SLK55, a few others
Is it me, or is it just a little low in the rear?
Old 02-23-2005, 11:25 AM
MBAMGPWR's Avatar
W215 CL600
It sits just above the fender, check the pic. If I wanted a gap, I would have left it stock.
Old 02-23-2005, 11:30 AM
MBAMGPWR's Avatar
W215 CL600
BEFORE:
AFTER
Old 02-23-2005, 01:49 PM
Super Moderator
BenzoBoi's Avatar
W221
Can anyone give me a 2 second cliff notes install on this? Is it really hard to do? Thanks in advance
Old 02-23-2005, 02:22 PM
MBAMGPWR's Avatar
W215 CL600
This is a quote I printed out from Peter B when I took my car in for the install...
"ben at (name deleted, pm if interested) has what are called lowering links (oe german mercedes parts). basically the same link the car has to lower or raise the car but instead of being fixed it is adjustable with a locking nut. he sold me 4 but my mechanic only needed 2 for the front and adjusted the rear sway bar adjusting point for the suspension. the cost is $125 a piece for the 2 and 3 hours installation. # is (delted, pm if interested). its adjustable by sliding the link then re-tightening the link with the adjustable locking nut on the front links then adjusting the rear to accomodate. ive had for about 300 miles and not bottomed out or anything. if you need to cross a spped bump just hit the suspension up button."
https://mbworld.org/forums/showthrea...lowering+links
Old 02-23-2005, 03:33 PM
Super Moderator
BenzoBoi's Avatar
W221
Thanks for the heads up!~!
Old 02-23-2005, 06:31 PM
Fast55's Avatar
Looks good, I just meant it looked lower in the rear than the front, at least to me. Wish it was that simple to lower a W210.
Old 02-23-2005, 06:48 PM
Kar don's Avatar
Mercedes-Benz
i think u need it just a TAD higher and then it would look perfect.
Old 02-23-2005, 08:41 PM
SamE55's Avatar
'04 E55
Your car looks really nice
Old 02-23-2005, 09:43 PM
Former Vendor of MBWorld
D2-AUTOSPORT's Avatar
VIPER
Looking good!
Old 02-23-2005, 11:24 PM
jdm2ths's Avatar
w211
i was wondering.. i lowered my e the same way... does the rear right sit 1/4 higher then the rear left? other post ive seen E's had problems...
Old 02-23-2005, 11:42 PM
JAY55's Avatar
///E63V10 ///F80CS ///Can-Am X3 XRS
I like it, like it a lot. I'll probably go with the same route as well. Thumbs up!!!
Old 02-24-2005, 12:02 AM
MBAMGPWR's Avatar
W215 CL600
Nope both the front & rear measure the same (the front sits a bit lower). No worries though, I can adjust in 15 min. easily. I took the car on the hwy today at 100mph with no problems. I still might adjust the front a bit higher, but it's not a big deal...
Old 02-24-2005, 12:15 AM
JAY55's Avatar
When you want to adjust it, do you have to bring it to the shop? Any special tools required to do this?
Quick Reply: Dropped the E55...
