E63 Jerky Transmission Issue
This problem was discussed here before and the problem seems to be with the multi-clutch transmission. I'm wondering if anyone has an update on this issue and if any measures taken has helped to resolve this problem.
The problem is not unbearable, but it is frustrating at low RPM's since it feels like the car will stop or something, and sometimes i end up pressing the accelerator pedal more which results in sudden quick accelration tht could be dangerous at slow speeds.
I have not taken this problem to the Mercedes service center yet, but if there is something they can do or should do, please let me know so that I can finally take this in to the service center. Thanks.
My Toyota truck takes off very smoothly. But, I still prefer driving my E 63
I really don't think there is a fix for this problem
When you come to a stop, I find that when the car/computer downshifts itself from 2nd to 1st the transition is very hard/jerky.
What I do is instead is manually shift down from 2nd gear to 1st on my own - it is a lot smoother.
Now for taking off at a stop I've noticed that if you have been stopped with the brake depressed for a long period of time, the transmission seems to take itself out of gear and places itself into Neutral. When this happens when you hit the accelerator there is a slight delay in take off. To help alleivate this - again in M mode - I flip the gear lever down and release the brake slightly, this seems to "re-engage" the transmission back into gear - but again if you hold it for too long it will set itself back into neutral.
You have to sort of play with it. It used to really bother me, but now I just treat it more like a manual transmission and it seems to feel better.
R
R
Apparently the early versions were even worse. They still haven't got it totally cleared up but I'm sure there will either be a hardware and/or software fix for existing models one of these days.
On the other hand, they may just dump this current automatic and use the SLS's proper dual-clutch automated manual transmission. That would be the best answer.
I think its a useful feature that gives your brake foot a rest at longer lights without the hassle of putting the car in Park.
The AMG speedshift 7G-tronic (w/a torque converter) had a TSB for an updated valve body replacement and software upgrade when it first came out. Your car should have had it done
Are you getting it replaced under warranty? You should be able to if the update hadn't been done even if it's just now out of warranty (2006)
Are you getting it replaced under warranty? You should be able to if the update hadn't been done even if it's just now out of warranty (2006)I think its a useful feature that gives your brake foot a rest at longer lights without the hassle of putting the car in Park.
