Did the Resonator Removal- not that much louder!!!
Old Aug 5, 2010 | 11:24 PM
Vic55's Avatar
Administrator
As the title says, I did the resonator cut out and replaced it with an X pipe- not that much more noise and I love sound. I think Im going to cut out the post cats too... no CEL and that should get me more noise.
I only wonder if Ill lose any power/tq? Anyone?
Old Aug 5, 2010 | 11:40 PM
gonzales25's Avatar
Slow
Cut out those secondary cats, you'll love the sound with x-pipe in place. I put my x-pipe where the cats were. The sound is insane.
Old Aug 5, 2010 | 11:57 PM
Vic55's Avatar
Administrator
Thanks, Ill do it for sure...
Old Aug 6, 2010 | 01:09 AM
Mockbam5's Avatar
W212 E63
Is there any drone by doing that??
Old Aug 6, 2010 | 01:10 AM
Verb04's Avatar
2019 AMG GT63S, 2020 Ferrari 488 PISTA
Sound clip???
Old Aug 6, 2010 | 02:46 AM
Racing Dad's Avatar
e63 2010 W212
keep us posted. i'm sure many of us would like to know your thoughts, i know i would. :-)
Old Aug 6, 2010 | 02:52 AM
SMP's Avatar
SMP
CLK63 Black Series
I removed my secondary's and deleted the resonators on my car. Put an x-pipe where the sec. cats used to be and straight piped the resonators. This way the torque remains the same and you'll pick up some HP on top. With an x-pipe, the exhaust will sound more refined. On my car, the mufflers have almost nothing in them from the factory. At start up it sounds more like an explosion. At least that's what my neighbors tell me. Above 2000 RPM, the sound is intoxicating. No drone at any speed, even when in 7th cruising. The E has more restrictive mufflers, so you should be fine. If it's too much sound, put the resonators back in place.
BTW, there is another H-like crossover just before the mufflers. So by deleting the resonators and replacing them with an x-pipe like you did, I'm surprised you made any sound over stock.
Old Aug 6, 2010 | 03:07 AM
aznflightfreak2's Avatar
2013 C63 AMG, 2015 S63 AMG, 458 Speciale
Where did you get your resonator remove? What X pipe are you using? Is it the magnaflow?
Old Aug 6, 2010 | 10:41 AM
Vic55's Avatar
Administrator
Thanks bro. If I leave the Xpipe at the resonator level and just straight pipe the post cats will I be OK?
As I remember when under the car yesterday; there is no H like crossover on the W212 post resonator. After the resonator the pipes just split left and right to the mufflers.
The car is louder at WOT... I just want louder all the way through. So I will go and take the cats out and see what happens.
The X-Pipe was a standard stainless that ACE muffler in OC had. They have done a lot of E63's (W211's).
I dont have a sound clip but will try to get one. I think Im spoiled with the loud header back system I had with the M3. After I had the resonator taken out, I went to my buddys wheel shop and they all said it sounded loud..
No drone--- in the cabin it seemed just marginally louder under throttle- just not enough for me. But for the masses who like the stock exhaust I think the resonator removal is a good thing, you will keep that nice start up and idle exhaust note with more roaaaaaaaaar at WOT.
Old Aug 6, 2010 | 01:54 PM
SMP's Avatar
SMP
CLK63 Black Series
Vic, if you straight pipe the sec. cats and leave the x-pipe at the resonators, you'll loose some power/torque and the car will never sound as good as the set up I suggested. I'm just trying to help you and all this information is of course just a suggestion .
The x-pipe should be as far forward (as close to the downpipes) as possible for optimum performance. This is where the exhaust should be balanced between the left and right bank. Since the secondary cats have a crossover from the factory, this is where the X should be. Never been under a 212, but the rest of the 63's all have that H-crossover right after the resonators.
Old Aug 6, 2010 | 02:10 PM
Vic55's Avatar
Administrator
Thanks and that makes a ton of sense--- cant take a chance on losing power- will give up sound for power all day every day. So now I have to go back and swap the x pipe to the front and then straight pipe the resonators---- Or I can just leave the car the way it is...
Old Aug 6, 2010 | 03:03 PM
c63101's Avatar
Auto
Either way just post some pics...
Old Aug 6, 2010 | 06:19 PM
gonzales25's Avatar
Slow
I had a h-pipe but mine was right before the 2nd cats, not the resonators? Maybe it's like that for the BS?
Old Aug 6, 2010 | 07:30 PM
SMP's Avatar
SMP
CLK63 Black Series
The BS and C63 has it for sure and I thought I saw it on the E as well, but could be wrong. On second thought, I'm sure you're right since you know your car much better than I do.
Old Aug 6, 2010 | 08:15 PM
Dbae1978's Avatar
2008 RPi BMW M5, 2010 E63 AMG, 2010 C300
Too bad you didn't do a before and after dyno! It would have been interesting to see if there was any power gains/loss.
Old Aug 6, 2010 | 10:48 PM
Verb04's Avatar
pics?
Old Aug 6, 2010 | 11:00 PM
Max.H's Avatar
E55
Ditch the x pipe Vic. No need for one that far down stream on the exhaust imo. Straight pipes should get you more sound. Weird but, when me and my friend straight piped 55 and 63. Seemed to get louder the next day.
Is it not loud enough in our outside the car?
Cat delete would sound mean.
Old Aug 7, 2010 | 12:12 PM
Mockbam5's Avatar
W212 E63
Ok, so what conclusion have we come to? Also with the work done, will it be easy to go back to stock when we have to return the car?
Old Aug 9, 2010 | 03:20 AM
Damn I want to go through Evosport for them to make me a custom mid-section. But I guess its best to remove the secondary cats and replace with x pipe. And remove the resonators and replace with straight pipe?
Old Aug 9, 2010 | 12:45 PM
SMP's Avatar
SMP
CLK63 Black Series
My exhaust was done by Evosport. Not only the exhaust, they also did the suspension, engine, brakes, some carbon fiber and a custom roll bar.
Old Aug 9, 2010 | 03:08 PM
Mockbam5's Avatar
W212 E63
So did evosport make a custom setup for you or do they sell the parts?
Old Aug 9, 2010 | 05:15 PM
SMP's Avatar
SMP
CLK63 Black Series
Evosport custom fabricated the exhaust set up and installed it while the car was there. It's a great set up and very well executed with clean welds and perfect angles on the X.
Vic, sorry for the hi-jack
Old Aug 9, 2010 | 06:20 PM
Vic55's Avatar
Administrator
No worries!!! Thats what these threads are for: experienced members to share their results.
I went back to x pipe the post cats and they didnt have the right size x pipe for that application. So Im gonna have them make me one and then go back later.
Old Aug 9, 2010 | 07:20 PM
Mockbam5's Avatar
W212 E63
It would be so much easier if they already made custom stuff for our cars so "newbies" can just order them
Old Aug 9, 2010 | 09:15 PM
gonzales25's Avatar
Slow
You can order an x-pipe from summitt racing, I bought the Magnaflow 3in universal x-pipe from them.
