Front license plate "no holes" holder
Old Jan 25, 2011 | 01:09 AM
eurowerx's Avatar
E 63,E55 (gone) E46 ///M ,B5 stage 3 S4 ,E36 ///M , 03 EVO (800 WHP)
Can someone direct me to where i might be able to find one of these, the ones i see are all for the C class or older models and i am not sure if out tow hooks are all the same. Thanks
Old Jan 25, 2011 | 04:40 AM
lyjw88's Avatar
C63s ED1 Coupe
The ones designed for the current C will fit the W212.
But you will need to modify a bit while installing.
Old Jan 25, 2011 | 11:25 AM
sluser123's Avatar
2010 W212 E63
are there any brands that people have liked/disliked? Where's a good place to get them?
thanks
Old Jan 26, 2011 | 09:33 PM
I am Jeff's Avatar
Steel Grey Metallic C63!!
thanks
www.gominigo.com
Old Jan 27, 2011 | 12:10 AM
RRnelcheeze's Avatar
CLS55
http://www.rhoplate.com/index.html
http://www.moweraxle.com/
http://www.cravenspeed.com/products/The-Platypus.html
Old Jan 27, 2011 | 12:46 AM
eurowerx's Avatar
Thanks guys, will let you all know how the fitment is.
Old Jan 27, 2011 | 09:41 AM
lyjw88's Avatar
C63s ED1 Coupe
FYI, I bought the one from gominigo.
You just have to bend the metal frame a little while installing. Nothing major.
Old Jan 28, 2011 | 03:44 AM
eurowerx's Avatar
Thanks.
Old Mar 16, 2011 | 02:10 PM
twowheelmarc's Avatar
2003 E55
What I did was take a zip tie, threaded through the hole of the plate, through a hollow plastic spacer, around the mesh grill, then back through the spacer and the plate hole again. I zipped it tight and then clipped the ends (still need to trim more). I used longer spacers on the bottom so the plate looks flush. Let me know what you think, all parts available at home depot for about $4.00
I'd have preferred black spacers but they didn't have any.
Let me know what you think.
https://picasaweb.google.com/marcfra...eat=directlink
Old Mar 18, 2011 | 01:11 AM
eurowerx's Avatar
I ordered the one for the 63 from one of the venders mentioned above and it does not work!!! at all! i am going to need to buy many washers because our tow hook seems much deeper than the C classes, when mine went all the way in i had to unscrew a lot to use it. Then it isn't tight and the plate moves with ease . Also u can see where the tow hook cover is off/ it doesn't cover the hole. I am going to try and mod it and see what happens.
Old Mar 18, 2011 | 04:07 PM
2003 E55
Revised link, hope this works.
Old Mar 22, 2011 | 10:12 PM
m3m3m3's Avatar
I'm in the same boat. A got a fix-it ticket for no front plate.
Which one did you get? I want something that will easily work out of the box..
Old Mar 23, 2011 | 01:57 AM
eurowerx's Avatar
http://www.rhoplate.com/index.html. this is the one i ordered but it doesn't work. someone on here told me with minor mod it will work but it sure doesn't.
Old Apr 10, 2011 | 12:41 AM
Vader13's Avatar
W211 E55 AMG, ML63 AMG, Past 996GT3,ZCPM3,Brabus C32,ML 500
I just ziptie my front plate one, the E55s still have the mesh, to us small black zipties one.
Old Apr 11, 2011 | 01:56 AM
aznflightfreak2's Avatar
2013 C63 AMG, 2015 S63 AMG, 458 Speciale
gominigo.com FTW. bought one for a E and C63. Both work great!
Old Apr 11, 2011 | 04:20 AM
eurowerx's Avatar
You can only buy it for a C, and i have it and it doesn't work. Maybe for a regular E but not for my 63. what mods did you have to do? looks like its gonna need a couple big washers
Old May 1, 2011 | 11:19 PM
m3m3m3's Avatar
So I ordered the gomingo kit. I actually measured out the distance from the bumper edge to the tow hook screw. I spoke with their sales guy and he sent the kit with an extension arm. I did use all the washers and got it to fit. It did take a little bending but it works great.
Old May 2, 2011 | 01:37 AM
eurowerx's Avatar
Even with the extension you had to use all the washers? who did u speak to i have to call over there and get this piece. does it cover the hole?
Old May 2, 2011 | 12:53 PM
m3m3m3's Avatar
I talked to Jason at Gominigo. He is solid and was very helpful.
Btw, I also used the offset bracket. I guess if you used the standard bracket, it would have fully covered the hole.
Attached are some pics of what it looks like installed. Sorry they are blurry, blame it on my cell phone :P
Attached Thumbnails Front license plate "no holes" holder-img00117-20110502-0839.jpg   Front license plate "no holes" holder-img00118-20110502-0840.jpg
Old May 6, 2011 | 01:14 PM
m3m3m3's Avatar
Looks like I was dumb.. I placed the offset bracket in the wrong direction. That is why I had to bend it. It should actually point the other way.
eurowerx - did you get yours setup ok?
Old May 6, 2011 | 02:17 PM
eurowerx's Avatar
HEy M3 thanks i haven't got around to calling over there yet but i going to give them a shout monday, have u tried the regular bracket?
Old Mar 8, 2012 | 03:34 AM
E-SICKTY3's Avatar
'13 CLS63 PP, '16 Huracan , '11 RR Ghost
What I saw there, you just disabled the parktronic with the tow-hook license plate holder on
I was trying to go the same route, but the parktronic problem makes me worried.
Old Mar 8, 2012 | 01:47 PM
otakki's Avatar
FF. W212 E63 M156 non-pano 18" P2 ParkT NightV (gone but will be missed).
I'm glad I'm no longer live in the NJ/NYC area or in a state that requires the front plate. Got two no-plate tickets while in NJ back then, one in Kearny and one in Newark.
Old Mar 12, 2012 | 06:53 PM
m3m3m3's Avatar
My car doesn't have parktronic so I never encountered an issue. Plus I just put the front plate on to get the ticket signed off and then took it off right afterwards.
I would recommend calling the guys at Gomingo - they were really helpful!
Old Oct 22, 2012 | 07:08 PM
dsl's Avatar
dsl
2010 e63
thank you for the ideas
Hello,
I am new to this forum and and a new owner of a 2010 e63. I am in California, so front license plates are a must, especially in Los Angeles. I used twowheelmarc's idea and went a little farther by using j-bolts with aluminum spacers and capnuts to clean it up. I didnt have to take off the bumper or drill any holes. hopefully the image i uploaded shows ok.
Dennis
Attached Thumbnails Front license plate "no holes" holder-20121022_155407.jpg
