Does ESP kill it...?
ESP on, ESP sport, and ESP off.
ESP on will kick in immediately if it senses the car losing traction. ESP sport will allow a little tail slide before traction kicks in. ESP off is where the fun is, you can burn rubber for days with no problem, its a total monster with it off.
If you are a reasonable driver who knows how to modulate the throttle and have control in turns this mode is the best for the W212 E63. Never use this mode in the wet though.
Turning off the ESP is not dangerous.....i have it off 90% of the time...if you are scared of turning it off, then I'm sure the car exceeds your skill with it on
Every modern performance car has ESP.....and your can turn it off.....If you "launch" from a light you use race start that gives you optimum RPM and traction....otherwise you just turn it off....
You need to drive the car and not come to conclusions from a post in a forum
When someone tells me leaving it on eats rear brakes, I say "not if you are doing it right".
Now what I have found on the W212 is that the Pre-Safe and BAS kicks in a lot easier than on my W211. I was consistently getting it kicking in under hard braking into turn 2 at Laguna Seca. I have only had it kick in once in my W211 and I can easily understand why, I was totally out of shape.
Here ya go
http://www.youtube.com/watch?v=iQz4nUyjMXU&feature=player_embedded
LOL OK
I'd love to test drive an E63, but there are none in the area. As well, the biturbo E63 has yet to arrive at dealerships (if I'm not mistaken), so that would make it kind of hard.
Here ya go
