Tune, new plugs
Old Dec 27, 2012 | 09:18 PM
  #76
Mockbam5's Avatar
W212 E63
Please share the information, would rather try different plugs than deal with the stock ones.
Old Dec 27, 2012 | 10:32 PM
  #77
rac3rx's Avatar
BiTurbo E63
What temp is everyone's m157's running? Mine has been getting around 210 after driving it for awhile. And 220 if I drive it even a little hard dos t seem normal? But never payed attention before I got a tune
Old Mar 4, 2014 | 09:20 PM
  #78
Ray G's Avatar
Sl65
Sorry for resurrecting an old thread but there is some good info in here and I just came up with the exact same problem. Car started shaking wildly after the check engine light came on. This happened once when I first got the car tuned but didn't happen for a while. This has now has happened several times in the past few weeks. It always happens whenever I romp on the throttle quickly. Scanned for codes and I am showing misfires in 6 cylinders. I have the off the shelf Renntech tune with no other mods. Just ordered new plugs from them.
Old Mar 5, 2014 | 12:10 PM
  #79
Traffic53's Avatar
Renntech E63S
listen. this situation is somewhat unresolved.
misfires on these motors are a dime a dozen. tune or no tune, renntech plugs or stock. doesn't matter.
that said, i'd caution your purchase before thinking these "cooler" plugs will resolve the issue. they are expensive, and don't seem to do any better than stock plugs. the only constant that has been observed so far is that these motors seem to trash plugs for some reason. consider having your local dealer swap in new stock spark plugs under warranty
Old Jul 20, 2015 | 04:40 PM
  #80
Bsalamone1's Avatar
2010 e63 amg
Originally Posted by NickE63
Its not the tuner, i just got my car back its the plugs, car runs stronger than ever
Nick, I had a misfire on my rentech 2013 e63 Amg pp and freaked me out check engine on and flashing engine was vibrating and pulled over let sit for 10 mins and started back up and no cel and car is driving fine and strong, only put 500 miles since tune and it failed when I was doing 140 on expressway other than that I have never had an issue took to dealer says code was misfire and nothing wrong, it has 43k miles and I'm assuming stock plugs, could that be the issue? What plugs did they replace on your car? Did you replace with stock or upgraded?
Old Jul 20, 2015 | 04:56 PM
  #81
Bsalamone1's Avatar
2010 e63 amg
13 e63 pp renntech bmc filters misfire shaking
I had a misfire on my rentech 2013 e63 Amg pp and freaked me out check engine on and flashing engine was vibrating and pulled over let sit for 10 mins and started back up and no cel and car is driving fine and strong, only put 500 miles since tune but this is the hardest I drove it since and it failed when I was doing 140 on expressway other than that I have never had an issue took to dealer says code was misfire and nothing wrong, it has 43k miles and I'm assuming stock plugs, could that be the issue? I see a few people having similar issue and replacing with stock plugs? what shoukd I do? I have not driven hard since that incident so I'm not sure if it will do it again but I sure as hell don't want that experience again, any input or recomendations would be great thanks!
Old Jul 20, 2015 | 05:46 PM
  #82
PeterUbers's Avatar
Oh but everyone says the tune is safe!!!
--- would love to never have this issue either .. And if I do, it'll be easily covered under warranty as I will not have a tune
I hope you get your car fixed
Old Jul 20, 2015 | 06:03 PM
  #83
PaulE550's Avatar
2015 E550 Coupe
"Oh but everyone says the tune is safe!!!" Why do I get the impression that those are famous last words right before someone has to pull out their credit card and start paying for a series of repairs or modifications on items deemed no longer under warranty?
Sorry I couldn't resist. I hope he gets his car fixed too and that it doesn't cost him too much.
Old Jul 20, 2015 | 06:13 PM
  #84
PeterUbers's Avatar
Paul... Exactly. You have to PAY to play and I don't want that sinking feeling when I have a CEL that I'm about to have warranty work declined
Old Jul 20, 2015 | 08:36 PM
  #85
cyclezib's Avatar
s4
I know that Weistec, for their tunes recommends going with a cooler temperature plug.
http://weistec.com/all/e/e-63/2012-p...-upgrades.html
Old Jul 20, 2015 | 09:54 PM
  #86
unagi1's Avatar
'14 C63 507, '11 C300, '96 Cobra, '91 Mr2
Make friends with the owner of the stealership? Seems to work for some.
Old Jul 20, 2015 | 11:49 PM
  #87
Davidkuo0330's Avatar
2016 AMG S65, AMG GL63, 2012 AMG E63 With AMS Alpha 9 Package, Renntech 200 Catted Downpipes.
I kept my OEM and so far so good.
I do have a question that I'm sorry you have or had experienced, but what to look for or what do you hear if a spark plug mis fire? Anyone? Thanks.
Old Jul 23, 2015 | 03:05 AM
  #88
aoschadlin's Avatar
current '17 C300 *sigh* ('19 E63S, '14 E63S, '08 535i)
Oh if it's misfiring you'll know it.
I installed new plugs with my Weistec tune and just happened to end up with a faulty plug (replaced straight away by Weistec).
The engine shakes the car, there's no/little power and you'll get CEL's showing. Also if you can attach an OBD scanner, you'll see the misfire reading.
I added the new plug back in and the car is back to smooth and pulling like a freight train.
Old Jul 23, 2015 | 03:07 AM
  #89
aoschadlin's Avatar
I thought I read somewhere that The Weistec plugs are re branded Brisk plugs?
http://mesablackworks.com/Brisk-Spark-Plugs-colder-M157
Anyone know yay or nay?
Old Jul 23, 2015 | 03:26 AM
  #90
Thanks. Was talking to Renntech and they recommended the Renntech spark plus by NGK. Just order them spark plus, but have not had any issues so getting rid of the OEM plugs before I had to learn the hard way what a mis fire is.
Old Jul 23, 2015 | 03:28 AM
  #91
I know Renntech is made by NGK if that helps since NGK is well know in the spark plug industry, you know where I'm leading. Just saying.
Old Jul 24, 2015 | 04:39 PM
  #92
sighting's Avatar
e63s edition 1
I think i found the model number of the NGK plug renntech uses.. I am just looking for someone to confirm it
Update:
These 2 seems to be the ones thats the tuners are using. both are 8 heat range
NGK Laser Itidium $15
http://www.rockauto.com/catalog/rafr...0&partnum=1555
Brisk Silver Racing QR12LS $15
http://www.briskracing.com/brisk-sil...rk-plug-detail
Old Jul 24, 2015 | 06:48 PM
  #93
aoschadlin's Avatar
Not sure I can confirm it, Weistec have the model numbers removed from the plug. :-/
Old Jul 24, 2015 | 09:00 PM
  #94
After my tune. My temp has been in the 210-220 range. It's normal I was told.
Old Jul 24, 2015 | 09:01 PM
  #95
vdubpower's Avatar
i drive them all, fast and hard
212 max, only time it went over was during No FLy Zone events
Old Jul 28, 2015 | 12:55 AM
  #96
drop997stop's Avatar
08 E 6point3-sold- 11 caddy cts-v-sold, 2012 E63 Palladium Silver
Tune
Have been having misfire issues again eve with new after market plugs. Spoke to Kleeman (don't have their tune) and the guys really know their stuff. Went into detail about O2 sensors going faulty throwing the cel and misfire. Very detailed stuff but actually made sense. I have been throwing misfires and O2 sensor codes. Only issue is to truley find out the issue is to turn the car back to stock and then start diagnosing from there.lots of time and energy. Tune has been a headache. Not sure the power is worth it
Old Jul 28, 2015 | 02:52 AM
  #97
vdubpower's Avatar
who did your tune
Old Jul 28, 2015 | 07:02 AM
  #98
sdg1871's Avatar
2019 E63 S
Tune, new plugs
Where is your tune from?
I know one friend of mine with an E63 S with AMS tune reports CEL issues.
I have had no issues so far with my Renntech tune. But if I ever do you all will be the first to know it.
My 991 Turbo S has heat soak issue with my GIAC Stage 2 tune after the first roll race or quarter mile. But no CEL issues with it. Just a reduction in power by about 49-50 wheel hp to keep intake air temps in check with only stock intercooling
Old Jul 28, 2015 | 07:40 AM
  #99
Rock's Avatar
Administrator
Drives Slowly
I believe drop997 had a Eurocharged tune but I'm not sure he stayed with it.
FWIW, I've been running Switzer's P700 package (tune and downpipes) for over a year on stock plugs and it has been 100% bulletproof......knock on wood.
Old Jul 28, 2015 | 08:52 AM
  #100
PaulE550's Avatar
2015 E550 Coupe
Yes OP, please confirm whose tune you're currently running. Thanks
