Have any of you here replaced your pads and/or rotors yet?
Old Jan 28, 2013 | 09:32 AM
E-Ridium 63's Avatar
W212 E63
If you did, did you go back to OEM or did you use low dust like porterfield and if there is a reco on different/better rotors, I'm all ears.
Just a poll to the group...wondering what people's experience of the brake life have been so far. (I know it varies on your driving style, just curious)
Old Jan 28, 2013 | 11:50 AM
Raddoc's Avatar
E63 AMG
I purchased a 2011 E63 AMG with 4500 miles on it. The brakes squealed bad especially when dirty. I complained a few times and they finally checked with MB and found out there is a recall or "service bulletin" on them. Had them replaced with OEM ones. I still noticed a slight squeal but definitely better than before. I wonder if low dust brakes would help since they don't make any noise after washing but will when the dust builds up.
Old Jan 28, 2013 | 02:37 PM
sikm3's Avatar
Black '10 E63
Changed front pads recently with Centric's ceramic low dust pads. Jsut as good if not better than oem pads in regards to stopping power/distance. The added bonus of hardly any brake dust after 4 weeks of driving.......priceless! The rear wheels still have oem pads. The difference in brake dust emitted is night and day.
I still have oem rotors. I don't track the car so rotors cracking aren't a big concern of mine. Girodisc has some nice rotors.
Old Jan 28, 2013 | 04:43 PM
W212 E63
Thanks. How many miles do you have on your car?
Old Jan 28, 2013 | 05:33 PM
otakki's Avatar
FF. W212 E63 M156 non-pano 18" P2 ParkT NightV (gone but will be missed).
Do you happen to know the price difference between the Centric and oem pads?
Old Jan 28, 2013 | 09:36 PM
sikm3's Avatar
Black '10 E63
15K miles
Old Jan 28, 2013 | 09:41 PM
sikm3's Avatar
Black '10 E63
Approx. $150 difference for the fronts and $70 for the rears.
Old Jan 30, 2013 | 08:55 AM
sehyang82's Avatar
w212 E63AMG
Car has 14k miles on odometer, and pads are 30% remaining both front/back.
All the expendable parts are covered under warranty for 3 years out here in Korea, so I'll just have the dealer replace them with OEM pads. They hardly squeal and have no complaints for their performance so far.
Old Jan 30, 2013 | 09:30 AM
grane's Avatar
GLK350, SL63 AMG
wheel dust
I wash and wax my OEM MB wheels. This helps diminish dust and road junk making it easier to rinse off. Plus it helps the clear coat finish stand up against the elements. Use the same wax you use on your car.
Has anyone found an especially good wheel wax?
Old Jan 31, 2013 | 03:56 AM
Karl901's Avatar
Porsche 911 Turbo S 2014! E63S 14, Audi S8 13, CLS63 12, E550 12, C63 09, all tuned
Yeah, I just replaced my pads. I have to look what make I used, but went to the track and warp my front rotors then!
Old Jan 31, 2013 | 11:18 PM
lunarx's Avatar
07 M6 | 09 RX-8 | 07 LGT Wagon | 17 Bolt
People do not realize how good the stock AMG pads are. They are pretty much the highest performance you will get in a daily driveable quiet pad. It will be very hard to find a pad to match it on all levels. To beat the performance you need a track category pad, which would dust more and most likely squeel on light braking.
Old Feb 1, 2013 | 10:11 AM
sikm3's Avatar
Black '10 E63
I've used OEM AMG brake pads the last 2 years. I switched to Centric who manufactures Stoptech brake kits. I've seen no significant difference between the 2 pads on the street, which is where I do most of my driving.
Old Feb 1, 2013 | 11:20 AM
W212 E63
Thanks for all the replies....very helpful.
Here is a pic of the current state of my brake pads.....any thoughts here from you guys on how much life is left on this set of pads? I'm guess its down to 40% but not sure. Any guesses?
Thanks!
Attached Thumbnails Have any of you here replaced your pads and/or rotors yet?-photo.jpeg
Old Feb 1, 2013 | 11:23 AM
uclachan's Avatar
10E63
16k miles on odometer, and pads are 5% remaining both front/back.
going to replace them with OEM.
little surprised that brake only last 16k miles. that's all.
Old Feb 3, 2013 | 04:52 PM
lunarx's Avatar
Thanks!
Those pads look fine.
You can keep them untill the pad part (excluding backing plate) is 1/2 what it is now.
My guess is another 6-10K mi on those, depending on your driving conditions.
Another thing to keep in mind is that it's best to remove the wheel to view them from the top.
Then you can see if the inner pads are worn the same as the outer pads.
Old Feb 3, 2013 | 05:17 PM
lunarx's Avatar
They should not wear that quick, under normal conditions.
I think most people get 20K plus from a set, with normal driving.
Where, 1 track day can easily put 50% of wear on a set of pads.
5% is really low.
It would be interesting to see a pic of your pads.
You should never let them get below 15-20%.
Some people would change them at 30-50%.
It's good to get fresh pads on, before your rotors start to groove.
Old Feb 4, 2013 | 05:28 PM
W212 E63
Thanks, Lunarx. Thats about what I was thinking too. Just FYI to others, thats with about 19K miles on the clock (14K in NYC, 5K in suburbia)...so i'll likely get 25-30K on my set of pads.
Old Feb 9, 2013 | 04:01 AM
Jspeed's Avatar
E63 biturbo
This is my front pad after 12,000miles. Should i replace them and where can i order online? Is it the same part as the 6.3l w212?
Old Feb 12, 2013 | 04:52 AM
lunarx's Avatar
Looks like you have been enjoying those twin turbos.
Your pads do need to be changed as they will start running hot now (and wear even faster), with so little material remaining.
Here is what I see for your pads:
https://www.genuinemercedesparts.com...&siteid=215306
How do your rear pads look?
Rear pads are only $132, you might consider changing them too.
http://www.genuinemercedesparts.com/...nt=REAR%20PADS
I think you are supposed to change sensors also:
http://www.genuinemercedesparts.com/...mponent=SENSOR
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
