3rd row retrofit in AMG wagon? done.
the big question as to why there is no 3rd row in the AMG, or whether the retrofit would work, has been answered.
the answers are: spare tire; and yes.
the exhaust, the weight ratings, the horsepower are all silly, inaccurate explanations to why the option wasn't offered. my shop, chicago performance and tuning, successfully completed the project without modification to the vehicle. however, the last detail to solve is the spare AMG rim that stows under the seats. it's about an inch too wide. so, just as it was with the factory 211 AMG wagon, i am not running with the spare on-board...yet. the 212 version of the car came with a pretty large spare rim and collapsible tire. the E350, by contrast, has a bit narrower spare rim and tire. so, there's your ballgame.
now, will the E350 spare fit over the AMG brakes? good question indeed. if it does, then that's the obvious solution. if not, the shop will either engineer a solution, or i will just go without- as we did in the 211 wagon.
Thanks!
X
i would say to you, check the 2014 E350. if they are going to offer the 3rd row in the 350, i would feel perfectly comfortable with knowing you can fit the parts in the AMG car. i don't believe there have been changes to the cargo area of the 2014 car, so i feel like you're probably fine to assume you can do it just as i did. the E63 wagon was only an option for me if 7 passengers were possible, so i studied both the E350 and AMG cargo areas to establish if there were any obvious differences- including cargo weight capacities and exhaust packaging. no differences.
knowing that MB would certainly not be stamping out unique frames for the very few AMG wagons, i was confident the parts would just bolt right up.
2 compromises to consider: 1) the spare is just slightly too wide for the seat panels to fold away flush to the floor. working on this, but current solution is a can of fix-a-flat. no spare. another possibility is to see if the narrower E350 spare wheel bolts up over the AMG brakes. if so, done. 2) the cargo cover and retractable net unit that is standard in the AMG car won't allow the 3rd row seatbacks to lock into place in the vertical position. the current solution is to simply pop that unit off if i need the seats. however, i need to investigate the unit that comes in the E350 to see if it is the same as the AMG piece. in the E350, there is no need to remove the shade housing to open the 3rd row. i'll have a look and report any findings.
X
So let me get this straight, on an E350 wagon, the spare currently fits under the false floor for the third row?
Something to keep in mind is that AMGs typically get a different donut spare than other MBs. The newer ones (maybe 2007+) all have a 19" spare to clear the calipers for the front wheels. So for this reason, I doubt a spare from the regular E350 will work. Something you might consider especially since you're comfortable running without a spare, is to use the E350 spare for the back wheels since that will likely fit (but you'll have to check). This way in the 50/50 chance that you do get a flat then you can still use a spare on the back wheel. If you got a flat on the front, then you can use your fix a flat solution.
Just a thought!
It would be a bigger deal to get my local guy to fab a mod to the aluminum arm that interferes the spare, so I'm wondering if anyone has comments on the downsides of going with fix-a-flat. Less range, less speed, until you get to a shop? This seat project has been kind of involved so there's a part of me that wants to just go all the way and mod the metal, but I also don't want to do it just because, without a clear benefit.
the only 2 E63s with the rear seats! so, i think the clear benefit would be having the spare on-board. since my shop has a metal-man/in-house fabrication service, i might just have the metal guy either mod or make a completely new piece that is lower profile.
what i'm seeing is that the aluminum arm is not load-bearing at all. it might even only exist as a convenience to get the floor pan out of the way to get to the spare. that said, i wonder if we even need it. maybe something else could be engineered to keep the floor pan solidly in place?
another question for you: the cargo area cover? will your seatbacks open fully and accept occupants with the cargo cover assembly in place, or do you need to pop that out? our project was similar in that it took a bit of time to order some of the bits and get it all together. required a bit of patience, but very much worth it.
I agree that aluminum bar doesn't look structural. You bring up a really interesting notion that maybe it's not necessary at all. Maybe that pan can just be supported by fabbed 'towers' underneath. The gas strut and everything seemed overkill to me, like how often do you need to access the spare?
The spare seems to just rattle around now the carpeted well is removed, are you thinking you'll just put some carpet down there or something?
I haven't tried popping the seat back up with the cargo divider in place yet, only without. I'll check that.
I know the airmatics have leaked with no loads, just wondering what the dynamics are like when you sling that weight behind the rear axles
on the cargo divider, you're right that the seatback doesn't pop up with it in place. I test drove an E350 wagon a while ago and am almost positive there was a divider, and the third row seats were popped up, so I have to assume the E350 has a different divider. This seems crazy right? I would go all out and order it but can't really picture when i would need it, do you think you'll order it? I guess only for occasions where I'll want to drop the seats while I'm out, and be able to cover things back there. Doesn't seem that often offhand.
Still debating what to do about that aluminum arm, remove or modify. Can't decide which one's easier. Since your parts are all in place, I'd be curious which way you decide to go. in some ways it almost seems easier to just mod the arm, but would need to figure out how much that will be.
forgot to mention to everyone that I'm working with Sonic Motorsports in Mountain View, CA on this project. They've been great and I highly recommend them, even though this whole thing has taken quite a long time (I'll excuse them on that, given that there might be only 2-3 cars in the country that have this mod...)
1) My car did not come with a spare - only fix a flat. My E60 M5 does not have a spare either. This is not an issue IMHO. But - if you had a flat in the front - could'nt u move one of the rear wheels to the front to clear the rotors and put the E350 donut spare on the rear. Not the perfect solution - but I think it would work in a pinch.
2) I don't get the cargo cover issue. More info would be greatly appreciated.
Scott
By the way, would anyone care to mount it that way and show what it looks like?...I would love to see it.
Is there a list of parts you could share with us, I am very interested in this because this is the major hurdle of going with e350 or e63 other than money
Congrats to you and your awesome ride!
