E63 S vs E63 S 4MATIC
Old May 14, 2013 | 05:30 AM
NS_C63's Avatar
2008 C63 AMG
As the title says.
I know the 4Matic will be quicker off the line but how will it fair on top end.
4 WD drive cars generally fall short on top.
Anybody come across some tests to show otherwise?
Keen to see 1 mile times/speeds on these 2 models.
Old May 14, 2013 | 11:17 AM
Chocofishez's Avatar
2014 E63 S
4Matic will be faster everywhere other than way, way up top. 575hp and 590 ft/lbs is a lot to be sending to two 285 section tires.
Old May 14, 2013 | 10:39 PM
otakki's Avatar
FF. W212 E63 M156 non-pano 18" P2 ParkT NightV (gone but will be missed).
I'm also looking forward to such a comparison.
Old May 23, 2013 | 12:03 PM
TMC M5's Avatar
'14 E63S & '14 Audi SQ5
I have a theory that the E63 S will post better ETs at the track if both cars are wearing drag radials. The 4Matic will have a hard time doing a proper burn out to optimally heat the drag radials. Obviously, the 4Matic will win a 1/4 mile drag race if both cars are on stock rubber. But I can't wait to see what the E63 S 4Matic does right out of the box.
Old May 23, 2013 | 03:34 PM
2-550's's Avatar
2012 GL550, 2012 E550
Me too, if I ever get the damn car. Ordering new model cars through Merc can be an aggravating experience.
Old May 23, 2013 | 04:33 PM
Vic55's Avatar
Administrator
You wont have to worry about the comparo stateside--- no non AWD S's are being built for us.
I see the AWD taking an early lead with the launch and then the non S slowing pulling back at triple digit speeds. A rolling race would probably benefit the non S.
Old May 23, 2013 | 05:03 PM
2-550's's Avatar
You probably meant the non AWD euro S right? The S even with AWD has 35 more HP than non S model. That will more than negate the weight savings of the non AWD car.
Old May 23, 2013 | 06:14 PM
Vic55's Avatar
Administrator
Originally Posted by 2-550's
[/B]
OOOOps yes meant to say non AWD not non S- thanks.
Old May 27, 2013 | 08:15 PM
gmeup's Avatar
2013 E63 Bi Turbo PP
[/B]
You don't just factor in the extra weight of the AWD system you also have to factor in its drivetrain loss on top of the weight handicap. AWD loses more power as it gets distributed to all 4 wheels compared to RWD.
Thus your extra power is gone just from the drivetrain as it has less efficiency to harness the power from the flywheel to the wheels. Add the extra weight on top of this and the Non AWD S will be the faster car after the 60mph mark. Especially if you tune it, it will be a monster at pulling away in the top end.
Old May 27, 2013 | 09:25 PM
2-550's's Avatar
Uhhhh sure. We will see soon enough. And what's with the after its tuned bs. We are talking stock here not a tuned vs non tuned car.
Old May 28, 2013 | 03:04 AM
gmeup's Avatar
I was only giving an example about tuning to explain what the full potential of the RWD platform could be in the top end as it is detuned in stock trim.
The E63 S is tuned by AMG to have more power over RWD non s from factory to give it a torque and hp advantage to negate the extra weight and drivetrain loss.
That said if you tune the non s it will be definitely be faster than the S once it has traction and it will pull harder and faster.
It’s really a simple fact that one can’t defy physics, the RWD car will always be faster than the AWD given its lighter and has less drivetrain loss so it has to be quicker if it has equal power to the S model and it might still be as quick or quicker top end with the less power they give it from factory but I doubt it.
The way AMG have setup the RWD now with less power is to ensure it will be slower than the S model for the simple reason AMG don’t want their flagship model to be slower than the cheaper and entry level E63.
E63 RWD 410 kW (557 hp), with 720 Nm of torque
E63 AWD 430 kW (585 hp) and 800 Nm of torque
If you are only interested in their stock performance it will be fairly even top end but I can’t say which one will be faster the S has a significant hp and torque advantage. In any case Europe is the only country with the option to have both RWD and AWD as far as I know, so it doesn't really matter for us anyway as we can’t get both options, still I agree it will be interesting to know which is faster instock form once both cars have traction.
Old May 28, 2013 | 09:53 AM
2-550's's Avatar
Well said. I guess we will find out. Although like Vic said, only in Europe as we only get the AWD platform.
Old May 28, 2013 | 11:10 AM
2014 E63 S
Have you decided to stay in line for the E63, or are you getting the porsche?
Old May 28, 2013 | 12:30 PM
2-550's's Avatar
Going to have the wife take the 911 for an extended drive tomorrow and see what she likes best. She likes the looks of the porsche better but the practicality of the E. don't thing you can go wrong with either. We shall see.
