Suspension message!! Advise needed???
Old Jan 8, 2014 | 10:11 PM
sebc63's Avatar
2015 ML63
Just took of the 20s and put back stock wheels back because roads in NYC got so bad dont wanna screw up the wheels. I swap the wheels drive the car around my block and no issues. I let the car sit for two hrs and then go for a drive and this malfunction message pops up. Cant get rid off it. And advise what could be a problem here?
Old Jan 8, 2014 | 11:25 PM
grocery getter's Avatar
2016 AMG GTS Edition 1 Renntech
Take it to the shop most likely it is the air suspension in the rear...I replaced two in my 05 E500 4 matic wagon
Old Jan 8, 2014 | 11:56 PM
vdubpower's Avatar
i drive them all, fast and hard
either the pump, the bellows, or the shocks themselves....good think u are under warrenty
has the car sunk at all or is it sitting ok...
Old Jan 9, 2014 | 12:11 AM
sebc63's Avatar
2015 ML63
Originally Posted by vdubpower
either the pump, the bellows, or the shocks themselves....good think u are under warrenty has the car sunk at all or is it sitting ok...
It is sitting fine
Old Jan 9, 2014 | 12:13 AM
vdubpower's Avatar
dunno, let us know what u find out
Old Jan 9, 2014 | 07:56 AM
m0v30v3r's Avatar
AMG
Reset it by unplugging negative from the battery for about one minute. See if that helps.
Old Jan 9, 2014 | 08:37 AM
sebc63's Avatar
2015 ML63
Just tried it. Still same
Old Jan 9, 2014 | 10:50 AM
Traffic53's Avatar
Renntech E63S
you're in NY?
i've had same malfunction a couple times this winter. both times because the car was frozen. went away when the car was stored in the garage overnight.
Old Jan 9, 2014 | 11:00 AM
sebc63's Avatar
2015 ML63
Originally Posted by Traffic53
you're in NY? i've had same malfunction a couple times this winter. both times because the car was frozen. went away when the car was stored in the garage overnight.
Yes i am. I had the car in the garage for few days without driving it because of the crapy weather. I hope i have the same issue. Thanks
Old Jan 9, 2014 | 06:14 PM
otakki's Avatar
FF. W212 E63 M156 non-pano 18" P2 ParkT NightV (gone but will be missed).
Better print out that pdf service bulletin that is around on here somewhere and take it with you to service. You sure don't want to wait until it sinks so much that wheel wells sit right on the wheels. I haven't had that message since I took it to service armed with that pdf. Yeah, they had to replace a bunch of parts, including the bellows.
Old Jan 9, 2014 | 07:51 PM
Patric's Avatar
14 E63S Wagon, 16 GTS Edition1 (Sold), 17 SL450 designo edition
It seems like I am reading more and more issues owners are having with their rear air suspension. I don't know if it's a poor design, inferior parts or some combination but I hope MB has it squared away by the time my new wagon arrives.
Old Jan 9, 2014 | 08:03 PM
sebc63's Avatar
2015 ML63
I think the issue was the cold in NY. I didnt drive the car almost for a week. It was sitting in the cold garage. Today only in the morning the malfunction massage popped up but then after lunch i drove car all day and everything was fine but still going to a dealer tomorrow.
Old Jan 9, 2014 | 08:12 PM
vdubpower's Avatar
Airsusprnsion has had issues since always. Our w220 gets leaky shocks or bad compressor. Time plays a factor. Obviously not ideal in new cars
