where can i get some sway bars?
Old Jan 17, 2014 | 01:56 AM
pali63wagon's Avatar
2012 e63 wagon
i have a 2012 E63 wagon. im looking for sways?
any help is appreciated.
Old Jan 19, 2014 | 12:58 AM
2012 e63 wagon
No one??
Old Jan 19, 2014 | 09:29 AM
335X-ray's Avatar
2021 GLS63
2 things.
1. Very few wagons.
2. Don't know of any sways for the E63 sedan, let alone the wagon.
Only suspension mods I am aware of are springs or sleeve kit for front and module or links for rear.
Good luck.
X
Old Jan 30, 2014 | 02:06 AM
2012 e63 wagon
i cant believe nobody makes them for an e63 sedan..
im sure the rear sway bar on the sedan and wagon are the same.
so again hard to swallow that not one company would do it.
Old Jan 30, 2014 | 02:56 AM
vdubpower's Avatar
i drive them all, fast and hard
what wrong with whats on the car now
Old Jan 31, 2014 | 12:06 AM
2012 e63 wagon
There not aggressive enough. The car rolls all over the place. The front springs might help a bit. But in all the audi wagons I ever had I always put a bigger bar in the rear to keep the body roll down back there. The module won't help that.
Old Jan 31, 2014 | 12:10 AM
vdubpower's Avatar
maybe thats a wagon thing ....but these cars are pretty stiff, especially in sport plus suspension
Old Jan 31, 2014 | 01:43 AM
2012 e63 wagon
I have a wagon... E63 wagon. 2012
Was I unclear? Was figuring if it's made for sedan it would be the same part for a wagon.
Old Jan 31, 2014 | 01:34 PM
keyserS's Avatar
From: Llanfairpwllgwyngyllgogerychwyrndrobwllllantysiliogogogoch, TX
E63S wagon w212; GLC63; GLC300; 720S
90 W212 E63 wagons in registry on web for '12-'13-'14 in US
German company most likely to build, ergo TUV testing. $$$
Profit at best 150-200/unit.
Sales projection 10-15% max. so US maybe 10-12 units so for whopping $2000-2500 profit for entire run, minus TUV testing costs?
Irresistable business case.
It's a wagon that weighs 4400. It rolls some. Gravity, a law we can live with.
Old Jan 31, 2014 | 02:27 PM
2012 e63 wagon
It doesn't need to be wagon specific. I bet the rear sway bar on a sedan is exactly the same as on the wagon. In fact I'd like to confirm that. There's no way they put a different bar on the very few as you say wagons.
So the market is larger then just wagons.
So searching for sedan sways as well.
Old Jan 31, 2014 | 03:56 PM
stein2's Avatar
'05 E55 Wagon
Call Renntech and have them build you one or a set. Write a check and you'll can make one.
Old Jan 31, 2014 | 04:37 PM
GregMB's Avatar
There are several aftermarket companies out there that will custom-bend you a swaybar to your specifications.
If you can provide them with the factory bar (I'm assuming its a one-piece bent style) to use as a template they should be able to replicate it in a larger diameter bar material....
As I'm sure you know, a few extra mm of diameter would make a massive difference in bar stiffness.
I'm not sure where you are located, but a quick Google search found shops in So. Cal and Florida that appear to be the "real deal". You'll probably have to do all the legwork yourself, but it should be possible to get a custom one-off rear bar made.
-G
Old Jan 31, 2014 | 08:21 PM
sikm3's Avatar
Black '10 E63
To my recollection, only the front has a sway bar. The rears do not.
Old Jan 31, 2014 | 09:26 PM
2012 e63 wagon
I'm in so cal, what shops?
Old Mar 2, 2014 | 01:43 AM
2012 e63 wagon
there is a rear sway
while doing a very slight fender roll in the rear i found the sway. thing is the labor to get it out would just be nutz!
Old Mar 2, 2014 | 04:06 AM
vdubpower's Avatar
how low are u going to need fender roll
Old Mar 2, 2014 | 09:43 AM
benyl's Avatar
'10 F150 FX4 SCrew. '14 S212S
Buy a new stock one to use as a template:
http://www.mbonlineparts.com/parts/2...iagram=5718710
Old Mar 5, 2014 | 12:16 AM
2012 e63 wagon
not low more wide actually. 19/11 in the rear.
cant notice a thing and its perfect. no rubbing.
295/30/19 its meaty but all clear....just barely!
the module is set at .60" might take her to .65"
Old Mar 5, 2014 | 12:28 AM
2012 e63 wagon
not that i think i would do it but tech had an idea to
drill a second eye hole in the tab the way that H-sport does on there adjustable rears.
There is actually plenty of room. then connecting it to that inner hole would improve it a bit. but then i read somewhere that the air bags in the rear have sensors that also react to help stabilize body roll with air.. can anyone else confirm this?
anyhow that's about as far as id go. getting that bar out is a nightmare!
Old Mar 5, 2014 | 01:45 AM
vdubpower's Avatar
post some pics bro, lets see what u got
Old Mar 5, 2014 | 11:27 PM
2012 e63 wagon
A few I took with the IPhone.
[QUOTE=vdubpower;5963378]post some pics bro, lets see what u got[/Qwhere can i get some sway bars?-image.jpgUOTE]
If I can figure out how to post a pic. I put some in my album.
Old Mar 5, 2014 | 11:31 PM
2012 e63 wagon
Another
[QUOTE=pali63wagon;5964525]
post some pics bro, lets see what u got[/QAttachment 280799UOTE]
Old Mar 6, 2014 | 02:04 AM
vdubpower's Avatar
cool, upload the pics to photobucket or soemthing and they can b e bigger..
