Throttle lag from stop is annoying....
Old Jan 20, 2021 | 07:34 PM
  #151
Bilal Dinc's Avatar
e63 amg
Originally Posted by Yakatak
I've settled on a mid-green setting. Feels normal but cuts the lag waaaay down.
huh i never even knew this was a thing till this thread. feels like a cheap hack. youre not worried about longevity?
Old Jan 20, 2021 | 08:04 PM
  #152
Yakatak's Avatar
2016 E63 S AMG Wagon
Well...It's a hack....not exactly cheap. Longevity should be good;.. solid state, no moving parts. Doesn't abuse the vehicle (unless maybe if you ran it at the max setting constantly...and you really wouldn't want to do that.. It feels like a hack on our MIni, because the Mini already has a quick pedal-to-acceleration response. In my application (maybe not yours), I can bring the Mercedes response up to what I think it should be.
Old Jan 20, 2021 | 08:05 PM
  #153
Bilal Dinc's Avatar
e63 amg
interesting. you have me intrigured to do more research now. thanks for the input
Old Nov 20, 2023 | 11:06 PM
  #154
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
Lightbulb engine performance robbery...
Ecu tune helped immensely with the lag as did the tcu tune
Would it be interesting to find out how lag corelates with lazy VVT below 1500.RPM ?
What do ya think?
Old Nov 21, 2023 | 08:11 AM
  #155
PeterUbers's Avatar
What do ya think?
absolutely - I've been on this platform since 2014 as you can see and it's amazing we are just now potentially finding a solution to the mct lag (oil solenoid thread) ... more to come
with the ecu and tcu and sprintbooster I have no complaints about the mct - understanding it's mechanical limitations - it still has to be driven a certain way to not cause violent bucking
Old Nov 21, 2023 | 08:20 AM
  #156
kevm14's Avatar
04 E55 AMG (totaled), 07 S550 4Matic, 14 E63S
Yeah that bucking is no joke when cold, that's for sure. And yes, mine still does it (as expected).
I actually had an exchange with Eurocharged regarding stage 1 TCU tuning to get rid of all the dumb behavior. One of their responses seemed to say it's impossible because of what I learned as deceleration fuel cutoff (DFCO) and how power can't be responsively applied right after slowing down. I call BS on that. I think it's really just VERY aggressive anti-lash and anti-abuse programming. MB may have learned either a refinement or durability lesson somewhere in the past and that is just standard issue. The torque converter cars do it, too. My 07 S550 does it. Sadly, my 04 E55 was VERY responsive to the throttle with none of this BS. I do think 4Matic tuning is worse (see my previous comments).
But yeah proper VVT operation does generally make the car better to drive, especially on the low end.
Old Nov 21, 2023 | 01:19 PM
  #157
Chevota's Avatar
E550 Coupe 2wd (2016)
From what I see in my car its spark timing, specifically catalyst timing, that causes the bucking. So I set min timing to 3 deg, which is ~30 advanced over oem, and that basically fixed it. I doubt any tune will do that unless you specifically requested it.
My throttle delay varies. From a dead stop its very responsive, almost like a Holley carburetor, but at say 25mph the delay can be pretty bad, unless I downshift first.
