Went in for oil change, came out with new motor... W157
Old Mar 8, 2015 | 05:21 PM
AHI's Avatar
AHI
AMG GTR
Took my E63 in for oil service and a little rattle from the engine compartment back in September.
Long story short, I still don't have it back. Yup 5 months. They determined there was some sort of engine failure due to the first owner not allowing motor to warm up (crankshaft bent). I let my car run for minimum 5 mins before moving it, and I only had this car for a few weeks.
I really miss the power, since I've been driving a vast errday of loaners, E250 blue, C250 Coupe, GLK, and most recently a 2015 C300.
Here is a pic of the motor being reassembled at Mercedes Maple after being rebuilt at the AMG facility here in Woodbridge.
Old Mar 8, 2015 | 05:48 PM
grocery getter's Avatar
2016 AMG GTS Edition 1 Renntech
Nice I bet you are glad they are fixing it....hopefully under warranty as I would hate to imagine the cost of a factory AMG engine
Old Mar 8, 2015 | 07:18 PM
ProfessorX's Avatar
2012 E63 Tuned, 2020 Shelby GT350, 1999 S 420
The previous owner didn't allow the car to warm up???? Everything I read says warming up your car is a myth and it only waste gas.
Old Mar 8, 2015 | 07:25 PM
AHI's Avatar
AHI
AMG GTR
Yes I'm very happy. And yes under warranty. It was at 20,000 miles.
I never believed that it was a myth. Ive always warmed my cars up for at least 5 mins. I know people that don't, and are hard on their cars even in the first 10 mins of a drive. This is not good for cold engine parts under load, and I see the types of problems and noises they encounter.
Old Mar 8, 2015 | 07:28 PM
TTA850's Avatar
2015 E63S AMG & 2013 GLK350
Hope you don't beleive everything you read
Old Mar 8, 2015 | 10:19 PM
sdg1871's Avatar
2019 E63 S
I never beat on my car while it is cold. I wait for the oil temp to warm up first.
Old Mar 9, 2015 | 07:16 AM
robl45's Avatar
2011 AMG E63
Not to be Debbie Downer, but you are losing time on your warranty while they have the car not to mention your car is depreciating while you can't drive it.
Old Mar 9, 2015 | 10:45 AM
PeterUbers's Avatar
Did you negotiate for a warranty extension or for some payments for the time the car was in the shop
Old Mar 9, 2015 | 10:47 AM
PeterUbers's Avatar
Attachment 305288
Letting the car warm up for five minutes is prohibitive to normal driving routines, that is an absurdly long time for me to wait before I can even move my car I let the car warm up for about a minute and then back out and just go easy on it for the first few miles and wait for to warm up
Old Mar 9, 2015 | 11:53 AM
diver driver's Avatar
2014 e63 s amg
Too Long
I wait till out of high idle (depends on temp and other sensors) then easy till water temp is in the white and oil at least 100F.
Old Mar 9, 2015 | 01:30 PM
otakki's Avatar
FF. W212 E63 M156 non-pano 18" P2 ParkT NightV (gone but will be missed).
I don't warm up above 32 F; warm up 30 secs when it's below 0 F and 32 F; 1-2 mins for below 0 F. Then just get it on the road and go easy until the oil temp has reached the optimal temp. It warms up faster when you drive it than letting it sits there.
Old Mar 9, 2015 | 07:20 PM
AHI's Avatar
AHI
AMG GTR
I also put a combined 7,700 miles on cars that I do not own. This winter I had a ton of longer distance trips I had to make, and I saved my AMG from having to go through that.
This is a fantastic idea, and I will start working on this. I own the car outright, so it will have to be a warranty extension.
I use a Compustar integrated car starter (uses OEM fob), so I'm not sitting in it while it warms up. I have it programmed to shut off after 7 mins. So when I finally get in, she's totally warm and ready.
Old Mar 15, 2015 | 10:42 AM
e500slr's Avatar
2011 E63, 2013 CLS63
The reason you should warm up the car is because the engine doesn't just use one metal, it uses different metals which warm up and expand and contract at different temperatures. It DOES wear the motor when you redline in on a cold night after just starting it. Especially something with so much torque. It doesn't need to be a full 5 mins, 2-3 is still adequate. You can still put it in drive and move, just don't rev it alot, keep it under 2500rpms for the first 10 mins of driving. We're talking about bat-out-of-hell driving while it's still extremely cold. You can drive while cold but drive like a grandma.
Old Mar 15, 2015 | 10:46 AM
Quadcammer's Avatar
96 and 08 911 turbos
the warm up is not necessary. You simply take it easy on revs and load before oil is up to temp and you're fine.
Old Mar 18, 2015 | 06:36 PM
AHI's Avatar
AHI
AMG GTR
This is what I've been told by numerous engine rebuilders. And it's what I've believed as well.
Old Mar 18, 2015 | 08:13 PM
HGMotorsports's Avatar
Former Vendor of MBWorld
'92 300E, '06 E55
Seems like a lot of miscommunication here, sitting at idle while the car warms up is generally not recommended (but isn't a bad idea in very cold climates). You should absolutely drive the car moderately (stay out of high RPMs and don't floor the throttle) until the oil temp is close to operating temperature. The time a vehicle takes to get its coolant and oil to operating temp can vary wildly depending on the motor and cooling configuration, to give you an idea I used to have a BMW 335is which would get me all the way to work (12 miles) in the morning while the oil temp was still in the cold zone but my M3 is warm before I even make it to the on ramp of the freeway!
Sitting at idle for too long isn't great for the motor because you're spending too much time with the oil way below normal operating temp when it is too thick to properly lubricate the moving parts of the engine. Remember that too much of a good thing is just as bad as too little! The best thing to do is to start the car, wait a few seconds and then start driving. Just don't get in the car and plant the throttle up to 6,000rpm in the first minute of driving and you'll be fine.
Old Mar 19, 2015 | 09:41 PM
AHI's Avatar
AHI
AMG GTR
Thanks AG for the info.
I got my car back tonight. I was going through some serious boost withdrawls.
I've decided not to ask for compensation. I've instead asked for my warranty to be extended for a full year, and to cover my next 5 services. My dealership is amazing, my service guys are awesome. I don't need money for free. I had a loaner at all times, and my car didn't have to go through the winter, and I saved it about 7,000 miles.
Old Mar 19, 2015 | 09:46 PM
robl45's Avatar
2011 AMG E63
Extension is quite fair.
Old Mar 20, 2015 | 01:46 AM
UAG1's Avatar
GL, E63
totally correct and the E63 temp went up super quick even drive like a grand ma
within 5 min, all temperatures are usually up to normal for me.
