Whistling wind noise?
I get it between 100km/h and 130 or so. Sounds like an intermittent whistle. It's annoying. Any one else get this? I have scoured the front of the car for something and can't see anything obvious.
Interestingly enough when I drove another 2014 e63 at a DE it had the same whistle. Anyone?
'14 E63S, '13 G550, '06 E320 cdi, and a bunch of other stuff.
My 2014 E63 AMG S wagon had a similar issue. Thought at first it was from a faulty windshield seal. The dealer identified it with the aid of a AMG service bulletin as a design fault in a clip on the grill fascia. Unfortunately it took two attempts ay my local MB dealer before they eliminated it completely.
I have attached a copy of my service record if that assists you further. Good luck.
Interesting...I also thought this was windshield-related. Nice find.
hawkam68, I looked at your attachment -- do you have the AMG service bulletin number? It will probably be an easier conversation with my dealer if I give them that first, then tell them the issue.
2014 E63S; AMS 100 octane ecu tune; edok tcu tune; BB intakes; dyno tuned
Chocofishez described it pretty accurately -- for me it only occurs between 60-90mph, and not all the time. Same pitch as when you hear the wind whistling outside. When a) it happens and b) I'm not bumping the B&O it's annoying
Did you read the thread I linked which had a comprehensive discussion about the problem, and the solution, including the TSB #?
My E63 S sedan has this issue as well. Will be fixed on May 18 when a loaner becomes available.
My service dealer is aware of the problem and has already fixed two E63's with it. Requires an overnight stay so the grill can be fixed and the glue dried.
Do they have to take the whole bumper down??
hi - i noticed you are in NYC, do you mind if i ask which dealer you use in NYC? want to drop my e63 off for same issue but prefer to go to a dealer who has done this before... thanks!
thanks - a little out of my way but if my dealer (silver star) can't resolve the issue I'll definitely make a trip out to Rockville!
