Topping Off Coolant- Only Use Coolant or Distilled Water ok?
Hey guys,
For those of us that aren't immediately near by a dealer, is using distilled water acceptable to top off coolant or if not, what coolant type/brand do you use? Been getting the low coolant light the last few days. It goes away once the motor warms up, so I'm not super worried about it.
Thanks!
Thanks!
2016 AMG S65, AMG GL63, 2012 AMG E63 With AMS Alpha 9 Package, Renntech 200 Catted Downpipes.
I would not top off with distilled water water because if the coolant is low enough the coolant light came on, you
must add allot of water to it to top it off and might end up flushing the whole thing. I would do a search to see what coolant is recommended by Mercedes and buy it off eBay.
Good luck.
Good luck.
Water works better than any coolant out there for keeping the engine cool. However it does not protect the engine from rust and calcium deposits. Topping off with water will NOT hurt the engine.
Using all water in sub freezing temps can cause some problems though
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
Using water is fine, it has the best absorption properties, it lacks the
lunrication aspect of coolant. Little bit of water will not hurt the system. If you use all water and live in an area that has freezing temps then yes it will be an issue, since water will freeze / expand and crack some lines
