Hello, want to throw a sale out there for you guys for a couple weeks! 2012+ RWD E63 Tune and Downpipes for $2650 plus shipping! Downpipes are catless and are Turbo Back. That is where the large gains come from!
As you all know, our tunes are 1 day turn around, so you will need to overnight your ECU to Houston with a return label and get it back next day. Gains on downpipe and tune over 150whp and over 200wtrq.
Is there a new tune optimized for these CKS downpipes? I bought them from CKS direct but have yet to install, and already have your tune. Should I hit up Jerry for a new tune for these?
and as others have mentioned, the stock pipes are made that way to not touch the heat shields and make room, how do you by pass that with a straighter pipe?
Plus the sound from my exhaust is unbeatable, and tons of turbo whistle with these downpipes.
Hey Ahi,
You are running the exact setup I want. Did the X-pipe help smoothen out the sound? Any issues passing OBD2 emissions check? (Obviously it would fail visual but most states allow one "not ready" code and still pass)
Any sound clips of your setup??
Thx
I had the x-pipe installed about a month before the tune and Dp...
I don't think this current setup would ever pass emissions. I don't have any sound clips unfortunately, but it's the loudest you could get short of removing the mufflers.
Do you have a new tune file optimized for these downpipes in specific? I got and EC tune from Jerry back in sept, but if there is a new version to support these I'd be happy to send the ECU back.
If you purchased the DP's, yes we would retune your car for them.
so if i am reading this correctly, there was no gains for the addition of the downpipes? I ask because in your other thread for tune only results you gained 153whp without downpipes... am i missing something? i would of thought true turbo-back dp's would of added another 30-40 whp to your previous pickup of 150whp on tune only
