UPD V8 Biturbo Cold air boost kit
Old Apr 30, 2020 | 01:49 PM
  #326
Kwish's Avatar
2010 Mercedes E550 and a 1997 S600 Coupe
Just curious, I've got a 2013 E550 with the 4.7 twin turbo V8, will this kit fit? I'd be interested in it if it does fit my engine.
Old Apr 30, 2020 | 02:33 PM
  #327
cocobeex's Avatar
2014 E550 4MATIC TUNED - Turbo Upgraded Stage 3
They will fit.
M278
Old Apr 30, 2020 | 03:33 PM
  #328
Kwish's Avatar
Awesome! I'll have to order it soon! Thanks!
Old Aug 8, 2020 | 04:23 PM
  #329
Ghostcls550's Avatar
2014 CLS550
Discounts?
Any discounts for your air intake kit? Interested if so
Old Aug 8, 2020 | 04:27 PM
  #330
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
PM sent.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Aug 8, 2020 | 06:57 PM
  #331
Kwish's Avatar
Interested if there is a discount now as well
Old Aug 8, 2020 | 07:18 PM
  #332
PLATINUM SPONSOR
2003 CL55
Pm sent and you will feel a nice power bump from this easy bolt on. Real easy bolt on power for the bi turbo.
__________________
www.ultimatepd.com
Old Aug 9, 2020 | 03:31 PM
  #333
mgrzelecki's Avatar
W212 E63 AMG S
Could you PM me the info as well, please? Thank you!
Old Aug 9, 2020 | 03:43 PM
  #334
PLATINUM SPONSOR
2003 CL55
PM sent.
Just to clarify, the M278 Mercedes 550 4.7 Biturbo and the M157 AMG 63 5.5 biturbo use the same kit and both cars use same air filters and air box sizes.
__________________
www.ultimatepd.com
Old Aug 9, 2020 | 11:37 PM
  #335
Amr_c63's Avatar
14 polar white E550
I have the spacer and I had a question , do the airboxes sit at a slight angle for anyone else ?
Old Aug 18, 2020 | 10:05 PM
  #336
Jules AMG's Avatar
AMG 63S Estate
Originally Posted by Stereolab42
So I installed this and believe I am noticing an increase in performance and (desirable) exhaust noise. From that standpoint it's a win. However it's a cosmetic disaster... the engine cover is pinched in and bows upward (middle clips no longer stay latched), and the ECU is like an inch underneath it. Is there nothing than can be done to improve this?
UPDATE: I "unpinched" the middle clips on the engine cover to provide better grip and they actually stay put. It looks a LOT better now, the engine cover is no longer "bowed". There is still a small gap between the ECU and the cover though. It would be nice if there were some sort of spacers that could go under the ECU to raise it up (hint, hint).
Can you elaborate on what you did here to "unpinch" the clips? (maybe a pic or video). I installed mine today and everything is great so far except the fitment of the main middle engine cover. Thanks.
Old Aug 18, 2020 | 10:12 PM
  #337
Jules AMG's Avatar
AMG 63S Estate
They do for me too. Looking to see if anyone has a fix for this. At the end of the day it is only cosmetically off a bit though so not too stressed about it.
Old Aug 19, 2020 | 02:06 PM
  #338
Kwish's Avatar
The kit works great for me, the only issue I had was a minor cosmetic issue of the main middle engine cover does not fit flush anymore it has to be bent slightly for the clips to fit into the airboxes. Eventually I'll work on it to see if I can make it fit properly or maybe find an aftermarket cover that looks a little better. If anyone makes one haha
Old Aug 20, 2020 | 01:35 AM
  #339
maxusa's Avatar
2013 E63 P30, 2010 GL550
Of course, this is an expected cosmetic downside of any brand airbox spacers. The same thing with UPD and VRP spacers. The problem is that the rigid turbo ducts remain in the same spot, but the airbox top cover moves up by 20mm. Ideally, the interconnect rubber sleeve shall 'adapt' to the 20mm rise, but it does not. The original duct connection is reused without adaptation.
And so the airboxes tilt towards the engine middle and forward. This creates a mostly cosmetic problem with attaching engine covers. The clip eyelets in the back of the airboxes shift up and tilt toward the engine. This puts a squeeze on the central engine cover from the wings. The central cover bows upward even more and disengages from the midpoint clips. The ECU appears way down in the 'hole.' The small engine side covers also sit about 1 cm higher and must tilt forward even more to engage the front posts. Although this issue does not affect performance, but does not look good either.
A simple compromise solution is to install 6 post stand-off extensions: 4x M6 12/25mm stand-offs for the ECU, and 2x M6 12mm stand-offs for the side covers. You need 2x 12mm for the front ECU stand-offs and 2x 25mm for the rear. There are excellent close-up photos earlier in the thread. Source M6 hex stainless steel stand-offs from eBay (~$20) or McMaster-Carr (~$60). The middle clips of the center cover remain disengaged (can be ignored, really). You can install eyelet risers. The resulting look is much better and almost OEM.
Old Nov 12, 2020 | 02:02 PM
  #340
PLATINUM SPONSOR
2003 CL55
Black Friday sales at Ultimatepd.com ...M157/ M278 Customers have been installing our kits seamlessly for 8 years now and all it takes is loosening up both sides of the rubber hose, leave everything loose until you lock boxes in place and then tighten up the clamps. Same thing on my personal and just like changing out air filters. Very simple and clean look VS using parts that are not welded and may leak or alter the engine bay looks dramatically that the dealer may get butt hurt.
car and it is as easy as changing air filters.
__________________
www.ultimatepd.com
Old Nov 12, 2020 | 05:15 PM
  #341
billvp218's Avatar
m157 SL63
Which intake parts need to be welded?
Old Nov 12, 2020 | 09:12 PM
  #342
maxusa's Avatar
I believe the reference is to the main competing spacer product that is a set of interlocking bars forming the spacer frame. In contrast, the UPD spacer frame is welded and anodized; therefore, offering better air seal and not attracting unwanted dealer attention/criticism. Did I get this right?
Old Nov 19, 2020 | 11:00 AM
  #343
PLATINUM SPONSOR
2003 CL55
Thumbs up
Well said and correct.
__________________
www.ultimatepd.com
Old Nov 19, 2020 | 12:00 PM
  #344
billvp218's Avatar
m157 SL63
Has there been thought of adding some kind of a rubber piece to help the air seal? I have had two p1ce7 codes (one 6 months after the other) where I have to take off the UPD intake & re-tighten it.
It's fairly easy to take off the intake, re-tighten, & then clear the code, but I'd rather not have to. It seems like it would be helped with some kind of compressible seal between the pieces.
Old Jan 11, 2022 | 04:26 PM
  #345
Jimrowe0's Avatar
72 corvette, 02 Z06, 06 CLS55
If there is a forum discount on these, I would like to buy one for my 12 cls550 (m278). Thanks
Old Jan 12, 2022 | 02:00 PM
  #346
Amr_c63's Avatar
14 polar white E550
If anyone is looking for a set PM me I have a set with very limited usage and hardware .
Old Jan 21, 2022 | 11:01 AM
  #347
PLATINUM SPONSOR
2003 CL55
Black version on sale right now. with filters or just spacer kits.
http://ultimatepd.com/2011-2020-merc...kit-black.html
http://ultimatepd.com/2011-2020-merc...l63-black.html
__________________
www.ultimatepd.com
Old Aug 30, 2022 | 11:25 PM
  #348
Krule77's Avatar
2014 E63S
Originally Posted by Deezbluballz
When its time.... Shardul, what do I use to clean the filters?
do you still have these kits? Need one for a 2014 e63s
You have already rated this thread Rating: Thread Rating: 1 votes, 4.00 average.
