Post the dyno numbers of your m157 biturbo car
Old Mar 14, 2016 | 03:26 PM
mjd222's Avatar
e63
I will tommaro
Old Mar 14, 2016 | 04:22 PM
kponti's Avatar
E63
Can you explain your dyno numbers a bit more? I see 3 pairs of numbers
Old Mar 15, 2016 | 04:40 PM
vkudenko444's Avatar
Mercedes E63 AMG S 4Matik
Here is my dyno chart on the flywheel (full GAD built 5.8 stroker kit):
Old Mar 15, 2016 | 05:24 PM
gaspam's Avatar
2014 E63s amg 4matic, 2009 C63, 2006 E55 AMG , 2001.5 AUDI S4 stg 3+ w/meth
has GAD made any progress on removing the torque limitations down low?
I know they are pushing the envelope on this platform and you have a good relationship with them so was curious as if you might have some insider info as to where they are at with the torque limitations
Old Mar 15, 2016 | 06:00 PM
dav461's Avatar
GTR
You mean removing torque limitations on MCT gearbox from the acceleration on the start ?
Old Mar 15, 2016 | 07:42 PM
gaspam's Avatar
yes, how its seems to buffer torque until about 3000 rpms on most m157 dynos i have seen.... on a lot of renntech and weistec’s M157 dynos i see torque jump about 225 ft-lbs from 2500 to 3000.... for comparison on my e55 i saw only about 30 ft-lbs change in the same rpm range and for c63 weistec stage 2 s/c you see about 20 ft-lbs change in the same rpm range
Old Mar 15, 2016 | 09:11 PM
  #32
Yes, they did. besides i have now Race start at 4.5k rpm (.5k higher). The car makes 0-60mph in 2.5 sec.
Old Mar 15, 2016 | 09:12 PM
  #33
dav461's Avatar
GTR
Have you spoken to weistec or gad? i am sure they can remove it.
My car will be ready on thursday and then i am going to think about gearbox as well. Will speak to kleemann first.
Old Mar 15, 2016 | 10:27 PM
  #34
efiftyfizzle's Avatar
W212 E63 AMG S Model
What mods are done to your transmission? I'm sure 4.5k launch is tough on the trans and clutches.
Old Mar 15, 2016 | 10:33 PM
  #35
gaspam's Avatar
awesome! was it just change to software or trans as well?
get your car to a drag strip when winter ends over there as we all want to see your beast on a drag strip!
Old Mar 15, 2016 | 10:35 PM
  #36
I think this is the guy that ran the 10.2 that you posted in another thread.
Old Mar 15, 2016 | 11:03 PM
  #37
gaspam's Avatar
Nope that car was from pp performance in uae... Vasily is from Russia with GAD motors
Old Mar 21, 2016 | 02:37 AM
  #38
AHI's Avatar
AHI
AMG GTR
I made 705wtq and 575whp
Eurocharged tune, DP and BMC filters
Old Mar 21, 2016 | 10:28 AM
  #39
2012 CCB E63's Avatar
2012 E63
dyno sheet?
Old Mar 21, 2016 | 11:51 PM
  #40
AHI's Avatar
AHI
AMG GTR
Originally Posted by 2012 CCB E63
dyno sheet?
I can't post my dyno sheet from my iPad for some reason, but here is my thread.
https://mbworld.org/forums/w212-amg/...ml#post6730951
Old Mar 23, 2016 | 06:12 AM
  #41
SSleeper's Avatar
'17 G63 AMG
No dyno sheet to post yet, but this past Friday during TX2k16 the car did 471rwhp/517.8rwtq on a Mustang dyno at about 60°F. 2012 E63, UPD filters/spacers, & QTP cutouts. It was tuned this Monday, but haven't dyno'd since.
Old Mar 23, 2016 | 09:15 AM
  #42
kponti's Avatar
E63
Who tuned it?
Old Mar 23, 2016 | 11:40 AM
  #43
SSleeper's Avatar
'17 G63 AMG
UPD/Tony since he's in town for the week; didn't have to ship the ECU.
Originally Posted by kponti
Who tuned it?
Old Mar 23, 2016 | 03:13 PM
  #44
2012 E63
So those #s are PRE tune it appears from your time line.
I would love to hear the after numbers also!
Old Mar 23, 2016 | 03:20 PM
  #45
SSleeper's Avatar
'17 G63 AMG
That's correct. The numbers I posted were before the tune.
Old Mar 29, 2016 | 04:18 PM
  #46
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
Here are mine and pulls were done on a hot humid Texas day.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Mar 29, 2016 | 04:38 PM
  #47
2012 E63
Who tuned it?
Old Apr 28, 2016 | 11:30 AM
  #48
Ralcbah's Avatar
2018 E63S
Put the car on the dyno a few times this week to see how the addition of catless downpipes and a retune would change the numbers...
Baseline - renntech tune, BMC filters, 93 octane, 90 degrees, Dynojet 424 LC2
best run (also first run):
- 586 awhp, no torque numbers...
After addition of catless DPs (not turboback), and software update, same dyno, probably a bit cooler (haven't seen temp numbers yet, but prob closer to 80 degrees)
- 620 awhp
I'll post graphs later and a sound clip. Also going to put it back on in the upcoming weeks to capture torque numbers.
Old Apr 28, 2016 | 12:01 PM
  #49
gaspam's Avatar
- 620 awhp
how does it feel with the addition of catless downpipes ?
Old Apr 28, 2016 | 12:07 PM
  #50
Georgee6086's Avatar
1994 E500, 2012 e63
- 620 awhp
Did they just turn off the rear O2's on re-tune or did they make others changes?
